Question about Kenmore Refrigerators
How do I reattach the deli drawer front Kenmore Elite stand alone refrigerator (circa about 2012)
Posted by Terri Wieghat... on
5 Related Answers
Anonymous
  • 1028 Answers
SOURCE: kenmore pedestal for the front loading elite washer and dryer
some pedistals have a screw on drawer just behind front on end of rail newer ones have a small black lever on each side ..pull drawer completely out lever is about midway at end of inner rail pull lever 1 up other down drawer will pull off rail reinstall by sliding rails back together and pusing all the way in
Posted on Jun 11, 2008
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 02, 2008
tzweeb
Tom Zwiebel
  • 318 Answers
SOURCE: Kenmore Elite refrigerator won't stop making ice
sometimes when you pull the shelf in and out, it will bind on the shut off arm and cause it to "pull out" of the i/m module. the arm has to be put back into the back of the module. you can take the i/m out of the freezer or just use a mirror and look for the place the arm goes. it looks like a 1/4", round, white plastic slot. the arm just pushes into the white piece and thats what causes the i/m to shut off when full or when the arm is lifted up.
Posted on Dec 28, 2008
Anonymous
SOURCE: I have a 10 yo kenmore coldspot refrigerator. We
I had the same problem. The water resovior in the back of the refrigerator had a pin hole in it.
Posted on Jul 11, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Kenmore Elite Drawer Dishwasher leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ppi
Posted on Sep 29, 2010
Items in deli drawer keep freezing
is the freezer freezing too? to much ice build up? if not check ur damper vent, make sure its not stuck closed or open to far, check the thermistors, the tempeture control thermostat, defrost timer and defrost terminator
Feb 19, 2015 | Kenmore Refrigerators
Frigidaire French door model 28 cubic ft - deli drawer freezes cold cuts and cheeses. Model FGHN2866PF1
Hello friend, thanks for your inquiry!
I understand that you have a Frigidaire refrigerator, FGHN2866PF1, and your deli drawer is freezing items. You may want to turn down the temperature within your deli drawer, when adjusting the temperature could take 24 hours for your refrigerator to stabilize. If that does not resolve your issue I would suggest removing the drawer and checking over to make sure there are no cracks where too much air may be coming in. If there is too much weight in the deli drawer that could cause the drawer to sag, which may release cold air into the deli drawer. I hope this information has been helpfu. -Matt
Oct 10, 2014 | Frigidaire Refrigerators
Broken shelf
The small meat or deli drawer tracks show to be avail for replacement as a left and right part. Front and rear screws are shown for each track. Since these parts are shown by themselves, the parts should be replaceable alone. Part# 63001371 is the left track Part# 63001372 is the right. About $5.00 each. The full shelf is a Part# 67001532 @ about $31.00. Pleazer Appliance...
Apr 07, 2014 | Maytag MTB1891AR Top Freezer Refrigerator
Deli drawer freezing food
The temperature in the section or the refrigerator isn't set correctly.
Also, check the thermostats if it is functioning correctly. PLEZE LET ME KNOW.
Sep 17, 2012 | KitchenAid Refrigerators
Kenmore Refrigerator 596.73503200 deli drawer cover hinge pin on right side broke off. Part #?
I would direct you to this link to find the part number you're looking for. I do not have one of these units to look at so am unsure which specific piece you'll need to replace.
Model 59673503200 KENMORE ELITE KENMORE REFRIGERATOR Parts
Nov 03, 2017 | Refrigerators
I purchased whirlpool GX5FHTXVA and there is a divider piece of plastic taped to the bottom of deli drawer, I have no idea where it goes. It is not in the manuel.
The wider end of the piece can be hooked anywhere on the back of the deli drawer. Keep the piece bent when you install it or it will scratch the glass on the front of the drawer. Also, make sure the tip of the smaller end is touching the bottom of the drawer before straightening the divider._1165.jpg
Apr 17, 2011 | Whirlpool GX5FHTXVA Bottom Freezer French...
Cracked fronts of drawers GE profile PSS26LSRCSS
Try the GE website or these:
  1. GE Fridge Parts Onlinewww.AppliancePartsPros.com/Parts      Good prices on GE fridge parts. Same day shipping. Order now!
  2. Ge Profile Refrigerator Partswww.RepairClinic.com      850,000 parts, 93,000 photos. Call center, same day shipping
  3. GE Refrigerator Partswww.pcappliancerepair.com      OEM source of GE refrigerator parts Online or toll free 1-877-922-2880
May 29, 2009 | Refrigerators
Refrigerators Logo
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
