Lands Phones Logo
C
CASSIE BUECHEL Posted on Mar 10, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a Norstar phone system AND I am programming from an M7310 and am able to change the date and time, but once I do, the time stays "Stuck" on what I've changed it to. How can I resolve this?
MrFixitSTTL
Level 3:
Master:
  • Master 340 Answers
  • Posted on Mar 10, 2020
MrFixitSTTL
Master
Level 3:
Master:
Answers
340
Questions
0
Helped
166824
Points
1713
Set System Time
1-Feature **TIME
2-Password: BASIC
3-Change time as prompted in the display
Testimonial: "THAT IS NOT HELPFUL"
1 Related Answer
consultel1
george peters
  • 860 Answers
  • Posted on Oct 02, 2009
SOURCE: We have a Norstar phone system and I am having
Sounds like there might be a software issue.Did you try power cycling the system for about 10-15 sec. to see if that corrects itsself?
Also when you enter programming, what does the first sreen say a. configuration or terminals and sets?
How to change a time on NT8B20AB NorStar M7310
You don't change the phone time, you need to change the system time for all phones on the system.
Norstar How to program phone how to program voice mail features for... b41664b0-f579-4647-a0ad-d844545b8148.jpg
7helpful
How do I change the time on the display on my NorStar M7310 phone?
Changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___"
12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
I have the Norstar M7310 and can't change the time. In programming feature, it asks for a password. Nothing will type in the area once I reach that part. What am I doing wrong?
Athough the digits don't appear on the screen they are being entered into the system.the 2 passwords you can use are 266344 (config) and 23646 (admin).
5helpful
How do I reset the time on a m7310 norstar system
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
7.- Select AM or PM
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
16.- Enter month
19.- Enter day
1helpful
How do i change the time on a norstar m7208 phone
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4" 2.- Enter password (default = 266344) - display should read "Terminals & Sets" 3.- Press "NEXT" 5 times - display should read "Time and Date" 4.- Press "SHOW" - display should read "Hour:___" 5.- Press softkey "CHANGE" 6.- Enter hour - display should read "AM OK or Change" 7.- Select AM or PM 8.- Press "NEXT" - display should read "Minutes:___" 9.- Press softkey "CHANGE" 10.- Enter minutes 11.- Press "NEXT" - display should read "Year:___" 12.- Press softkey "CHANGE" 13.- Enter year 14.- Press "NEXT" - display should read "Month:___" 15.- Press softkey "CHANGE" 16.- Enter month 17.- Press "NEXT" - display should read "Day:___" 18.- Press softkey "CHANGE" 19.- Enter day 20.- Press "NEXT"
We have a Norstar phone system and I am having trouble changing the "Date and Time". I am programming from an M7310 and am able to change the date and time, but once I do, the time stays "Stuck" on what...
1helpful
Norstar 7324 time change
Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 266344 which also is Feature * * config.
If asked for a password enter 23646.
When in programming2.gif just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, just press back (lower left)
Example: To change the Time & Date Press next until you see Time & Date. Then show Then change Then change again, change it if you need to, Then next again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press next until you come to the Hour. Then Change it. Then press release RLs when your done.
4answers
Norstar CallPilot 100: need to change the time within the system to reflect daylight savings time
the time change goes off the system time to change system time press feature **7463 enter the admin password then press change and enter new time
Changing the date and time
Do you have the ADMIN password? If so you cna change the time and date by logging into the system, press next until you get to " Time and Date " and change it there. If you do not have the ADMIN password please let me know and I'll try to help. ....Mitelmike
2answers
Norstar m7310 phone
Rushy: I assume you have a KSU which controls the entire system. The KSU is cabled to each line number provided by your local phone company. Once you have this line established it now makes contact with your phone set via dedicated cabling to each telephone set.. With all this hardware in place you can now program the line keys on each set for either one touch dialing or line access for your dial tone. Program guides can be aquired through GOOGLE by entering " Norstar m7310 program guide".Thank You. Jerry
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
