Question about Dirt Devil Vacuums
SOURCE: dirt devil vibe 088915v
Are you talking about the beater bar? If so, you probably have a broken belt
Posted on Jan 16, 2009
SOURCE: the belt is intact but the aggitator doesn't spin
It could also be a bearing problem in the roller brush. Take the belt
off of the roller brush and see if the brush spins freely, if not, remove the
roller brush and check both ends to see if one end is stuck. If so you
need a new roller brush or there might be hair rapped around the bearing keeping it from turning freely.
Tom
Posted on Oct 22, 2009
SOURCE: dirt devil dynamite spinning thing isn't spinning
does the unit have a belt?
Posted on Feb 01, 2010
SOURCE: i dont have a manual for the dirt devil vibe
Information on your Dirt Devil Vibe Bagless Quick Vac M084500V can be found here:
http://www.dirtdevil.com/products/details.aspx?id=M084500V#parts
A link is available to download the manual as well as for replacement parts.
Yes this model has a belt to run the power brush; the manual has replacement instructions.
If dirst is being left behind it could also be a problem with a blockage, overfilled dirt cotnainer, or problem with the filter.
Posted on Apr 18, 2011
SOURCE: How do i fix a dirt devil simpli stick
Check if it has fuses and replace them. Check the circuit breakers and where (wall outlet) you're connecting it by connecting for example a lamp that is known to work somewhere else. Check that the dirt bag's empty. Get a technician or a new one as a last resort. Whatever's cheaper.
Posted on Oct 20, 2014
Apr 11, 2011 | Dirt Devil KONE Hand Vacuum MO213BLU...
Mar 27, 2011 | Dirt Devil M084500V Vibe Quick Vac Bagless...
Mar 05, 2011 | Dirt Devil M084000 RoomMate Upright Vacuum
Feb 01, 2010 | Dirt Devil M084600 Dynamite Bagless...
Aug 29, 2009 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Mar 15, 2009 | Dirt Devil Featherlight Bagless Upright...
Jan 16, 2009 | Dirt Devil Featherlight Bagless Upright...
Jul 30, 2008 | Windsor SR12 Sensor Bagged Upright Vacuum
