Question about Mio Watches
I have a Mio Stride Petite and the vinyl watch band has broken. Can it be replaced?? I love my watch and wear it all the time.
Posted by Lorie Butkus-Hill on
Attique-ur-Rehman
    Top Expert:
  • Mio Master
  • 2,677 Answers
Https://www.amazon.com/Stride-Heart-Rate-Monitor-Watch/dp/B001KYEYZW/ref=cm_cr_arp_d_product_top?ie=UTF8
Posted on Mar 09, 2020
Testimonial: "I want to replace the watch band not the watch. The watch works perfectly."
5 Related Answers
Anonymous
SOURCE: Replace strap Cousteau Explorations watch
Can not find a resource to repair broken watch band. I do not have model number. I only know the dial says exploration. There are no model numbers on the watch case.
Posted on Sep 03, 2008
Anonymous
  • 26 Answers
SOURCE: larger clasp
Unfortunately, I do not think this is going to be an easy fix. You may want to take it to a local independent watchmaker. Gucci may sell larger clasps but they may be difficult to find even from them directly. I have looked at the watch you have. It it was solid gold a Jeweler could just make it a touch larger.
Looking at the clasps the options i see is
Have the bangle removed and wear it on a leather strap,
Possibly remove the clasp where it says gucci and have the pins laser welded so that the clasp stays in a fixed position similar to a bangle.
mike --consumerwatchguide.com
Posted on Jan 03, 2009
Anonymous
  • 26 Answers
SOURCE: How to open Baume & Mercier Hampton Milleis ladies stainless band
Looking at your watch it looks like the clasp on the SS model is just a double deployant preasure fit. If it is brand new sometimes these style of deployants are vary tight.
It is Stainless Steel it is vary difficult to break it looking at the construction of the bracelet.
Basically you just Pull, there is no button it is just pressure fit.
mike -- consumerwatchguide.com
Anonymous
  • 11 Answers
SOURCE: finding replacement watch band
Hmmmm to get an orange rubber band you will more than likely have to go thru Bvlgari. I have access to a lot of watch band but I have not seen an orange rubber band in any of the catalogs I get. You can contact them at 1-800- BVLGARI
Posted on Jul 31, 2009
Anonymous
SOURCE: purchase watchbands for the timex 1440 sport
Hi, I saw 1440 Timex watches at target today when I was looking for replacement bands.
Posted on Jul 06, 2010
Where can I get instruction details for my POD 550 watch?
RCX5 found it surprisingly light and small. It doesn't look like a computer on your wrist like many other GPS watches. Of course that is largely because the bulk of the GPS components and battery are in an arm band.
The armband and separate GPS device seemed like, and became, one extra piece of equipment to worry about.
The watch, heart rate monitor and foot pod all use watch batteries. Battery removal can be difficult, however once the back is removed the batteries are easy to install and replace. The GPS piece is charged with a standard USB cable.
The speed and cadence sensors batteries are not replaceable. These sensors must be purchased again when they wear out
The speed and cadence sensors are attached to a bike with zip ties. I found them easier to install than the Garmin sensor largely because they are separate devices. It was easier to position each of them so that they picked up the magnet from the wheel/pedal separately, rather than trying to align one device to detect both.
Additionally the speed and cadence sensor each have a built in led light that flashes each pass of the magnet.
However, to configure your stride length is tricky at best. The best way to do it is to run a distance using the stride sensor that you know the actual distance of, then change the distance in the history. So let's say you ran 1 mile. The watch believes you ran 1.1 miles. By changing the history to 1 it should adjust the settings so that the next mile you run will record correctly.
Once you have been using the watch for some time you can get into advanced setup. You can add your own sports, or configure the devices, and screens setup with each sport.
You can do this from the watch, but it is easier to do it from the Polar Web Sync software. The software works much like a remote terminal for the watch. You connect to the watch and add or change each sport profile, or change user or device settings.
May 09, 2015 • Watches
Watch is frozen, will not reset or change modes
you will need to press the reset or a/c button located usually near the battery well with a pin and a magnifying glass
Getting heart rate on mio petite
Is your heart working? Sorry, bad joke. The only thing besides the watch malfunctioning is that you need to have your hand and arm relaxed when you touch the watch case. Apparently if your muscles are tense it can cause the monitor to not read.
1helpful
Changed battery, now buttons on sides do not work, where to get it repaired?
mcdevito75 here, Most likely during the battery change you moved the quartz movement away from the contact buttons. Re-Open your watch carefully and make sure when you press the buttons, each button is pressing against it"s spot on the quartz movement.
I have a Relic ladies watch that I wear all the time and just love. I recently had the pin to brake that holds the watch to the band. The jewelry store repair man had to drill the pin out to replace it...
mcdevito75 here, That pin is called a spring bar and is used to hold the band to the watch, the pin must be frozen in place on the watch, Best Bet is to try another jewelery shop, in the meantime you can put a drop or 2 of cooking oil on the pin just as it meets the watch this may loosen the remaining portion of pin.
I have a wonderful cardinal digital watch that I just love. I received this as a Christmas present from a dear friend. Unfortunately the large black rubber band has broken at the hole that I regularly use...
mcdevito75 Here, You may be able to find a replacement band on ebay, or look for a small watch repair shop in your area for a replacement or repair, the band may be able to be glued.
2answers
Purchase watchbands for the timex 1440 sport
My son's watch (WR 50M) broke... so I have a strap, if you'd like it.
He loved this watch and it would cost about the price of a new one to repair, so I'm buying him a new one. He's had the same watch for years... bless, huh?
If you anywhere I can purchase another WR 50M - 1440 Timex, I'd be most grateful.
1helpful
3answers
6700 gucci watch too small
Acutally nowhere. You have to shop around for all the jewellers or watchmakers shops to find it.
You can visit GUCCI wbsite as well, but it is very costly.
Please, rate me (if not happy- do not rate at all).
I HAVE KC 3500 WATCH.MY BAND IS IN TERRIBLE CONDITION.
You do not need exactly the Kenneth Cole watch band. Measure the distance between watch case lugs - this will be the width of your new band. Go to any jewellers shop you like, ask them to show all watch bands of this size and choose whichever you like. Ask them to fit it as well if you do not fancy to do it yourself.
In case if you have a buckle with KC logo and want to keep it, then take it with you and ask to refit the buckle as well.
Rate me, please.
Watches Logo
Top Mio Watches Experts
Lisa Christine
Lisa Christine
john h
Are you a Mio Watch Expert? Answer questions, earn points and help others
