Question about Radio Communications
How do you adjust the volume on the ihip bluetooth wireless light up headset
Posted by regina williams on
5 Related Answers
Anonymous
SOURCE: Plantronics 330 Bluetooth headset
the default security code is 0000.
Posted on Feb 10, 2008
Anonymous
  • 32 Answers
SOURCE: GN Netcom wireless headset volume adjustment
Transmit volume adjustment
Adjust the volume of transmitted sound according to personal preference.
To adjust the volume:
1. Make a telephone call and ask the person you are calling to assist
you.
2. Press the +/– buttons on the headset simultaneously for 2 seconds.
A beep will indicate when 2 seconds has passed.
3. Adjust the volume level by pressing the + or – button.
4. When the person you are speaking with fi nds the volume of your
voice appropriate, press the +/– buttons simultaneously for 2
seconds. This setting is now stored in the headset.
A Copy of the manual is avaliable at:
http://www.onedirect.es/files/GN%20Netcom-ES/GN%20Netcom%209120%20manual.pdf
You must have Adobe Reader to view it and the instructions are on page PDF page 3 or manual page 6. Adobe Reader is avaliable for download at:
http://www.adobe.com/products/acrobat/readstep2.html
Posted on Nov 12, 2008
Anonymous
SOURCE: volume control problems with motorola bluetooth
If its a motorola bluetooth, take it out and shoot it. Its the only way, and it will make you feel better. Thats the only this motorola bluetooths are worth!
Mikey
Posted on Dec 12, 2009
Anonymous
SOURCE: Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
Posted on Jan 28, 2010
award462
Anthony Ward
  • 397 Answers
SOURCE: i needs the manuals for n136 bluetooth wireless headset
try this:
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
How do I connect my blackberry cel phone to my bluetooth ce0678
Hi, you can use this instruction to pair your blue tooth with your cell phone:
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Good luck to you..
Feb 01, 2011 | Cell Phones
Now on the T60:
with your phone.
Select OK.
Nov 13, 2009 | Motorola Mobility S805 Wireless Headset
Top button on Plantronics 232 Bluetooth headset
Its for volume. you hold it down and adjust the volume.
Jul 05, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Volume too low. I tried to adjust higher - barely hear the beep as volume goes up, yet not load enough.
y is it that when some one call me i cant hear them in the earpiece i only can hear them in my phone
Jul 02, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
Insignia Bluetooh Headphone won't turn on. but can charge
put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
Jun 19, 2009 | Insignia Bluetooth Wireless Headphones...
Cant turn up the volume
Volume control, if not on the bluetooth device, can be adjusted on the cell phone depending on which cell phone it is. Try to look under bluetooth devices and if your headset is recognized you can be able to adjust volume. Otherwise.. check the manual :)
Hope you'll figure it out
Regards
Jun 05, 2009 | Motorola Mobility H3 Bluetooth Headset,...
Need to know how to adjust volume on bluetooth
by pressig the volume button up and down
on the handset press the volume buttons
any thing else idont know
Mar 25, 2009 | Motorola Mobility H350 Wireless Headset
Can this be fixed
Try adjusting the volume not only on your bluetooth but also on your phone as well. The 2 volumes are not associated with each other at all. If that does not work still, your Bluetooth may not be compatible with your phone or you may have a defective bluetooth. Make sure you within 18 feet of your phone when talking on your bluetooth. Hope that helps!
Mar 18, 2009 | Motorola Mobility H700 Wireless Headset
Volume problem
there should be a volume button on your bluetooth, or you have turned your volume down on your phone, which is most likely, thats what i had done, crazy huh.
Dec 19, 2008 | Motorola Mobility Bluetooth Hands Free...
Radio Communications Logo
80 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
