MHL accessory not detected - Televison & Video
Posted by Jayne Finn on
Andrew Taylor
    Top Expert:
  • Televison & ... Master
  • 31,465 Answers
Yes that is what it says
Today, MHL is primarily thought of as an "accessory" because it often requires an adaptor that converts the cable to HDMI. The reason is that most flat panel TVs does not support MHL and therefore the cable has to be converted to HDMI in order to connect it to the TV.Aug 1, 2012
Guide: What is MHL? - FlatpanelsHD
Posted on Mar 07, 2020
How to connect my nuvision tablet to my element TV # ELEFW328 using a MHL adapter kit
1st and foremost You can Only Connect a (MHL Enabled Device) to an HDMI TV . I Do Not know from the given information if Your Tablet is MHL Enabled ??? Here is a link to check your device Compatibility http://www.mhltech.org/devices.aspx . If it is Enabled are the services for MHL Devices started and running on Your Tablet Here is a video link for setting up MHL devices https://www.youtube.com/watch?v=GrBkQ4GUXf0&hd=1
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
May 18, 2016 | Tablets & eReaders
Does my metropcs samsung galaxy avant have mhl
Samsung Galaxy Avant: MHL:
Hello. Yes, MHL is available for all Galaxy family devices. You just need to obtain one that is compatible with your phone.
here's the Official one:
MHL 2 0 HDTV Smart Adapter
Note: You will need your charging cable and wall charging adapter. Plug power into the MHL and plug MHL into micro USB port on Galaxy Avant.
This MHL adapter can be used by the listed newer phones directly without a power adapter to show pictures on to your TV screen. It is not recommended to use without plugging in the power cable (that is plugged into the wall charger) if you are going to use the MHL for streaming video or for gaming, because those are power hungry and will deplete your battery within 2 hours or less. Connecting power charges the MHL as well as your device. Make sure your charging cable and wall charger are OEM, else they could just trickle charge your device instead of actually charging it. (some aftermarket chargers are 3V. Samsung's are 5V for the more power hungry Smartphones.)
You may need to turn airplane mode on
on some Galaxy Smartphones it is:
(my Note 4 on Android 5.1.1 is like this)
Settings>Connections>Airplane Mode
On your phone I believe it is:
(depends on the Android firmware version)
Settings>Under section: Wireless & Networks: Select More Settings>then check box for Flight Mode
*** Important ***
if you are trying to connect to the internet to stream to your TV, and Airplane/Flight mode turns off your WiFi, just turn it back on (airplane/flight mode will remain on) ~ some phones do this, some do not, this is carrier specific.. meaning the cellular provider requested the phone to auto do this for some reason
Feb 11, 2016 | Samsung Galaxy Cell Phones
Is my irulu x7 tab mhl enabled
Irulu Tablet - Android Forums at AndroidCentral.com
forums.androidcentral.com/other-tablets/236406-irulu-tablet.html
Dec 18, 2012 - 25 posts - ‎22 authors
The specs are below. ... I just got my irulu 4.2 Jellybean tablet and this is my first time dealing with anything other than desktop and non smart phone. ..... There is a hidden phone on the irulu X7 called dragonphone and I have ...
MHL Supported Products - Accell
www.accellcables.com/pages/mhl-supported-products
Now mirror your smartphone or tablet featuring MHL technology on a display or projector. Please ensure your device is MHL enabled by visiting the link below. •
Feature News Stories: How Do I Connect My Tablet to My ...
hometheaterreview.com/how-do-i-connect-my-tablet-to-my-tv-let-me-co...
Oct 14, 2013 - That means you must connect your MHL smartphone or tablet ... flash drive and plugs directly into an MHL-compatible HDMI port on your TV or ...
Amazon.com : IRULU X1a 7" Tablet - A33 Cortex-A7 1.5 ...
www.amazon.com/IRULU...Tablet.../B00M3OTG3S
Amazon.com, Inc.
Rating: 3.2 - ‎97 reviews
Jan 21, 2016 | Tablets & eReaders
Lg stylo will not work with slimport or mhl cable
LG G3 Help with the Best MHL Adapter... - Android Forums at ...
forums.androidcentral.com > LG Android Phones > LG G3
Sep 14, 2014 - 11 posts - ‎6 authors
I got this one Slimport™ to HDMI® Adapter - Black - Monoprice.com. ... Again, the LGG3 will not work with a MHL adapter, regardless of what ... Is there a way to get 'll g g stylo to Screen mirror or cast ...
Aug 17, 2015
HDMI to TV connection isue
May 15, 2014
Is A Special App. Or Setting Needed to use a Slimport ...
Oct 30, 2013
Anyone Using An MHL Cable With Ther Optimus g?
Nov 19, 2012
More results from forums.androidcentral.com
SlimPort to HDMI Video Adapter Review for LG G4 G3 G2 ...
? 1:27
https://www.youtube.com/watch?v=dy_ra3_A_JA
Sep 28, 2014 - Uploaded by EEEKit
Oct 30, 2015 | LG Televison & Video
Is LN40C630K1F samsung tv compatible with MHL? If not how do i get my phone mirrored on my TV, is there a way?
The Samsung LN40C630K1F is not MHL compatible. The HDMI port on the TV doesn't understand the signal from the tablet directly. You need an MHL to HDMI adapter: http://www.amazon.com/Cable-Matters%C2%AE-Adapter-integrated-Charging/dp/B00ESM3Q7K/ref=pd_sim_107_2?ie=UTF8&refRID=1A2PE0271GRC99HNF1G9 , instead of an MHL to HDMI cable. Be sure to make sure that the adapter is compatible with your phone. (Not all adapters work with all makes/models.)
I hope this helps.
Aug 04, 2015 | Samsung Televison & Video
How can I make it MHL compatible
do not know what MHL means but it is quite possible that they are non compatible items
Mar 28, 2015 | Cell Phones
How can I hook my alcatel fierce one touch two to my t.v. using mhl hdmi?
don't forget to connect to the power. on the side of mhl, it has a power socket for your mobile phone charger.
Feb 18, 2015 | Alcatel Cell Phones
I am trying to connect my Samsung galaxy S4 phone to my Phillips smart TV 55pfl4909 with mhl to HDMI wires, but it's not working. I've watched videos on you tube & its suppose to be simple but mine is not...
The problem with MHL to HDMI is that there are two versions.
a 9 pin and a 11 pin.
Samsung S3 and below use 9 pin and S4/Note3/etc and up use the 11 pin.
Not all samsung use MHL but the S4 does.
Make sure you have the right MHL cable for your device.
I have encountered this problem personally and have bought a universal cable which covers both versions.
My brother has a Sony and also had wrong cable.
Now it works fine with correct cable.
Dec 21, 2014 | Cell Phones
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
