Question about Toshiba Office Equipment & Supplies
I have toshiba estudio 3005ac printer. printer problem Error code c970. please tell me. how can i do fix this problem and how can i do this copier color adjust?
Posted by Jamal Uddin on
Ibrahim Din
    Habit-Forming:
    New Friend:
  • 27 Answers
Check the main charge.
Posted on Dec 02, 2020
5 Related Answers
TechRobort
Rehman Ahmed
  • 26 Answers
SOURCE: Needs windows Vista driver for Toshiba estudio 35.
hi dear,
pls search its driver at DRIVERGUIDE.COM
GudLuk
Posted on Nov 03, 2008
didi2005
  • 727 Answers
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
Posted on May 28, 2009
Tim Swiercinsky
  • 1126 Answers
SOURCE: Toshiba estudio 166 C44 error code
Hold "0" and "8" while turning on machine.....continue holding until machine enters service mode. Enter "400" press enter. Enter "0" press enter. Power off / on. If code returns, machine needs parts replaced. Do Not keep resetting, may cause damage to Fuser Unit.
Posted on Sep 14, 2009
SOURCE: How can i fix the
1. Check and clean the main charger, replace if required.
2. Check and clean the transfer/sep. unit, replace if required.
3. Before you replace the HVT board, check HVT connector bracket (the black color plastic piece mounted on the machine frame where the main charger connects). If this part is damaged or cracked, the high voltage will arc through this, which can cause C970. (found in several machines).
Posted on Dec 04, 2012
didi2005
  • 727 Answers
SOURCE: toshiba estudio 181 gives error code c44 any button not working
C44 indicates fuser problem.
Try perform 08-400, set to "0" to reset the error.
If persist, u need to check the themistor & heater lamp on the fuser unit.
Posted on Dec 14, 2012
Toshiba estudio 3040C. How do I change the IP Address?
user functions
admin
password
123456
network
ipv4
change from there
then apply
Hope this works
Jul 19, 2016 | Toshiba OEM ESTUDIO3040C 30 PPM Color/Mono...
Toshiba e232 is error code C970
Code C970 Description Process related service call
High-voltage transformer abnormality: Leakage of the main charger is detected.
Aug 09, 2015 | Toshiba Office Equipment & Supplies
It is blocked to call SAV,when i do clear+8 i have error C970.Please what is the solution?
C970 Process related service call High-voltage transformer abnormality: Leakage of the main charger is detected.
[C970] High-voltage transformer abnormality (1) Is the main charger installed securely? (2) Check if the spring of high-voltage supply contact point is deformed. (3) Check if the charger wire is broken or the main charger grid is deformed. (4) Check if any foreign matter is on the charger wire or main charger grid.
Jun 23, 2015 | Toshiba E-Studio 3511 Color Copier
Resetting error code c970 on toshiba e-studio
Karuna wire break
OR
its side charger problem clean it
OR
replace it
Mar 19, 2013 | Toshiba e-Studio 232 Black and White...
there is no reset code for c970 ...the cause of this is the second transfer roller grounding contact..check if there is foreign materials on the contact ...this error is grounding contact problem
CALL FOR SERVICE C970
OR
replace it
Nov 17, 2012 | Toshiba estudio 255 Copier
I have a toshiba estudio 2500c. I have error code C3B0. How do I fix it without calling a service person?
I have a toshiba estudio 2040c. I have error code C3B0. How do I fix it without calling a service person?
Sep 08, 2011 | Toshiba E-studio 2500c Color...
How can i fix the error code C970 on my toshiba e-studio 230?
Nov 01, 2010 | Toshiba e-Studio 350 Copier
Open Questions:
Top Toshiba Office Equipment & Supplies Experts
Timothy Van Der...
Muntejaya Ginting
Muntejaya Ginting
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
