Question about Home
What are some ways to repair your leaking toilet?
Posted by Mills Jack on
Adam Howard
    Habit-Forming:
  • 60 Answers
It depends on where it leaks. The wax ring that seals the toilet to the waste pipe could be old and dried out. The seal between the tank and the bowl could be old and dried out. The water supply line could be leaking.
If you want a stranger on the internet to offer you advice your question needs to be very specific. And you don't have a clue about toilets, best to call a plumber.
Sure this is fixable by a handy DIY person. But if that was you, then your question would have been more specific.
To know more about repair kits, check Best Toilet Repair Kits 2020
Posted on Mar 07, 2020
Vinesh K
  • 3 Answers
Below parts will be needed to repair your leaking toilet.
    ·Toilet tank drip tray
    ·Toilet tank insulation
    ·Adjustable or open-end wrench
    ·Replacement tee bolts
    ·Replacement wax ring .etc... we are from Pepetrip a certified packers and movers company . submit a request to get a migration done.http://pepetrip.com/packers-and-movers-chennai
Posted on Jul 22, 2020
Mukesh Panda
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 11 Answers
Tools and Supplies are required
The tools and material you require to eliminate water puddling around a toilet will vary, depending on the cause. Below parts will be needed to repair your leaking toilet.
    ·Sponge
    ·Bucket
    ·Hacksaw (if needed)
    ·Putty knife
    ·Work gloves
    ·Tub and tile caulk
    Instructions
      ·Check for Condensation
      ·Tighten the Tee Bolts
      ·Purchase a New Wax Ring
      ·Disconnect the Toilet
      ·Remove the Toilet
      ·Remove the Old Wax
      ·Install the New Wax Ring
      ·Reinstall the Toilet
      ·Reconnect the Water Line
      Actually I had suggested these steps to one of my friends and that worked. He had recently shifted to a different location and faced this issue. Initially, he had a doubt regarding the relocation of his households. But now after shifting smoothly, it was cleared as he didn't have to face any losses or damages to his belongings. In my opinion here is the best and reliable Packers and Movers in Andheri Mumbai.
Posted on Mar 30, 2020
brian williams
    Genius:
  • 1,864 Answers
Where's it leaking?
Why does it leak from the top outlet?
  1. SANIFLO upflush toilet - YouTube
    ? 6:14
    www.youtube.com/watch?v=-F1v6GIbWF8
    Aug 10, 2011 - Uploaded by Regis Saragosti
    Saniflo is the leader and inventor of the macerating toilet. ...Liberty Pumps Ascent II 1.28 GPF Macerating Toilet System - Install a Bathroom ...
Jul 10, 2015 | Saniflo Plumbing
Tip
How to locate leaks on a toilet
One of the major sources of water loss is due to a leaky flapper valve on toilet. Even with a small leak you can increase your water bills twenty to thirty dollars a month. And if you have several toliets some will be used more than others. The ones that are used the least often leak the most. The easiest ways I've found to locate leaks is to use common food coloring. Use any color you like,I prefer the darker ones as they show up better to me.Remove lid from toilet tank being careful as they are made of china and will break or crack if handled roughly. Put about ten -twelve drops of food coloring directly into tank. Check in about one-two hours. If flapper is leaking the water in the bowl will be discolored.<br /> Most flappers can be easily changed by home owner,some may <br /> require help. If you feel comfortable doing this the first thing I would do is try to identify type you need for replacement.Repair parts are available in plumbing dept. of most stores carrying hardware.I like to have repair parts on hand if possible. Shut off water supply to toilet. Remove old flapper and install new one.<br /> There are many different types so you may have to remove it to get the right one. If water won't shut off or you can't find replacement parts you proably should call a service co.If it is leaking very bad or you have more than one a service call will probably pay for itself in a couple months.Thanks.<br />
on Nov 07, 2010 | Plumbing
Toilet leak
You have to remove the tank and replace the tank gasket and the tank to bowl bolts and gaskets as well, do not reuse them, they will leak again.
Jul 25, 2014 | Bemis Home
How do I repair a toilet in a 1991 Pace Arrow
Is the water constantly running inside the toilet or leaking from behind. If it is running inside the toilet it is often cause by the valve not being allowed to return to the off position. This could be a result of a bad flush linkage from the foot pedal or handle or it could be that the ball or blade gasket is messed up inside the toilet. If it is leaking behind the toilet that means your water flush module has cracked and must be replaced. Turn the water to the coach off. Disconnect the water line to the rear of the toilet. Remove the nut on each side of the base of the toilet. Take the toilet outside and inspect every component and replace what has failed. It is very basic and simple to repair.
Jun 25, 2014 | RVs
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 | Home
Toilet leaks into floor and lower level ceiling, no water on bathroom floor.
Either wax ring or sewage pipe is leaking. If you cant open the ceiling from below to look for leak you may have to remove toilet inspect pipe and look to see if it was leaking from wax ring and if it could have gone downstairs without leaking out too. If leak couldn't have come from wax ring the leak must be coming from a pipe in the floor. Find the simplest way to access it to repair it.
Sep 14, 2010 | Toto Round Carusoe Two Piece Toilet, 1.6...
How do I fix a leaking toilet ?
****if its the tank supply line and one of the connections is leaking tighten the connection if stops done if continues to leak go to hardware ,home,or plumbing store for replacement $4-7 dollars turn shutoff valve off flush toilet to get most water out of way and disconnect line replace ****----if joint where valve is connected to main water feed if threaded try tightening connection if soldered will need to turn of water to bathroom or house and drain line and resolder connection same of pressure connection/threaded valve failure
Jan 25, 2010 | American Standard 2860.334 Enfield Two...
Old crane toilet, leak between tank and toilet, need new gasket.
You might try looking in an hardware store, or a plumbing shop that has been in business for a long time. Sometimes they have parts that can't be found elsewhere. I would take the old seal with you, if you still have it.
Apr 15, 2009 | Home
Home Logo
107 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
