SOURCE: i need for :yamaha keeboard psr 9000 :danish manual
hej I asked my lokal store. thank ouy for answer. best regards poulc
SOURCE: Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
SOURCE: Repairing Yamaha psr-12
If the power adapter is not the original adappter- check to make sure the polarity is correct- it should be marked on the keyboard near the adapter socket, and also on the adapter itself.
The keyboard should have an internal fuse- check that. Then with keyboard open, if the fuse is okay, trace the power flow from the power pack and look for broken wires, bad solder connections, stressed components like bulging capacitors, etc. It may have a burned out zener diode in the power supply regulator portion of the main circuit.
SOURCE: What's your problem?how can i connect my mic in YAMAHA PSR s710
I believe you must have a USB audio mic. If you do, plug it into the USB port in the back of the unit;
SOURCE: my Yamaha PSR S750 do not light up every thing is silence
No power is reaching the unit or PS is defective.
