Question about Kenmore Dryers
Kenmore 600 series powers on but start button just clicks. Same click when I try to change any setting. No error code
Posted by Ruth Keeling on
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: kenmore 90 series electric dryer
check the door swithch first.. won't start if its shot....
tthen look to motor start relay...??
Posted on Jun 13, 2008
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: Power button makes a click, click sound
The sound is coming from a failed flyback auto transformer. You will need to replace that.
Posted on Jun 14, 2008
Anonymous
  • 113 Answers
SOURCE: Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Posted on Dec 16, 2008
Anonymous
  • 360 Answers
SOURCE: Kenmore 70 series barely agitates and makes a clicking sound
What u have just described are failed agitator pawls/dogs, relatively easy fix. The repair comes as a kit. Most appliance repair houses will have the kit, if not www.searspartsdirect.com will have them
Posted on Feb 13, 2009
gamefixer
Stephen Frye
  • 6 Answers
SOURCE: Kenmore 80 series electric dryer will not start even though the door switch switch appears functional and power is getting to the timer.
Easy fix. I had the same problem on mine. You need access to the back. Remove back cover. Look at bottom left, you will see two blue wires going to a white plastic item next to one of the thermal sensors. This white plastic piece is a fuse, or fusible link if you like. I'm not sure what the rating is, but you can take the old one to a parts store. They can match it. Now, why did it blow? Well, if the dryer is old, it could be just worn out. But more than likely, one of your 230 volt lines has degraded due to a bad connection, thus drawing more amps, thus blowing the fuse. Look at where the power cord comes in at. Is there any discoloration or oxidation at the terminals? If so, replace the power cord at this time, and try to clean up the terminals as best you can. Also, at this time, you probably better take a look at the lint collector duct running along the left side down the back. It's probably so clogged with lint that your dryer does't dry as fast anymore, and air flow from the exhaust is restricted. Take the duct off and clean it out, or blow it out with compressed air. You should be up and running now. Have fun...
Posted on Jun 16, 2009
Kenmore series 600 dryer displaying PF code tries to start but doesnt then kick completely off
PF is power failure error meaning electricity has been interrupted to the machine. An electrical interruption of any type can cause a PF error code. Try this: Press the Pause/Cancel/Stop button twice to clear the PF in the display.
Courtesy: https://www.ifixit.com/Answers/View/285793/What+does+the+PF+error+mean
Oct 08, 2018 | Kenmore Dryers
How do i fix the error 000003-0000 on ir 3320?
Hi
Whilst looking through the web I found this procedure for clearing errors from ir series Canons. You might like to try it first.
  1. Additional Functions: Click the Additional Functions button once. Do not hold down.
  2. Two and Eight Buttons: Click the 2 and 8 buttons at the same time once.
  3. Additional Functions Revisited: Click the Additional Functions button once again. Do not hold down.
  4. Copier Button: The System Management screen will open. Click the Copier button on the screen.
  5. Function Button: Click the Function button at the top of the screen.
  6. Clear Button: Click the Clear button on the screen.
  7. ERR Button: Click the ERR button to highlight it.
  8. OK Button: Click the OK button at the bottom of the screen.
  9. Power Off/Power On: Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
If this doesn't work, I found a complete list of error codes here:
Error Codes Canon iR3320
There are 12 pages of them but yours appears to be on the first and related to the temperature of - or lack of - the fixing unit. From this site you can also buy a service manual which may also be helpful to you rather than the User Manual/Guide.
Cheers
Nov 14, 2014 | Canon Office Equipment & Supplies
try jumping the start button out on top if thats it ,replace it
Jan 15, 2013 | Kenmore Dryers
How to solve 5100 error of canon pixma ip1880 series printer
Follow this procedure:
1. Enter Service Mode: Hold Power button and plug a power cord, then push Resume button twice and release all buttons.
2. Free Download from Internet: GeneralTools for Canon Pixma IP1880
3. Starting GeneralTools
4. CHANGE USB PORT change into PORT of your printer
5. click lock release
6. click ip1800
7. click device id
8. clear waste ink counter by clicking MAIN & PLATEN
9. Check EEPROM Box
10. Click EEPROM Dump
Power off printer and all done. Work again!
Jan 11, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
I have a 600 series kenmore dryer and the heating element turns on when i set the timer and before i push the start button
Sorry to read about your problem, I hope this helps you out.
sounds like your start button is stuck on...
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Kenmore 600 6965 Electric Dryer
Epson workforce 600 displays message " A scanner error has occured. Please refer to documentation" How do I fix this?
Error 600
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 26, 2010 | Epson WorkForce 600 All-In-One InkJet...
Canon mp510
Feb 07, 2010 | Office Equipment & Supplies
Canon mp 600, errorcode 5c00
  7. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Oct 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Won't ignite or start
HI .Thanks For The Question. The Problem you Have is With THe Coils, On The Gas Valve. Replace. THe Coils .THanks The Appliance Doc
Sep 17, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
82 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
