Saws Logo
Boniface muinde Posted on Mar 06, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Juki dl8700. What causes it to smoke while sawing?
Abdul Rasheed
Level 3:
Master:
  • Master 567 Answers
  • Posted on May 26, 2021
Abdul Rasheed
Master
Level 3:
Master:
Answers
567
Questions
0
Helped
181494
Points
1403
Blunt or damaged blade or chain.
ray gallant
Level 3:
Top Expert:
  • Saws Master 74,163 Answers
ray gallant
Saws Master
Level 3:
Top Expert:
Answers
74163
Questions
0
Helped
655397
Points
561709
1 Related Answer
Anonymous
  • 63 Answers
  • Posted on Sep 22, 2010
SOURCE: the motor in my saw is smoking. What will
May need cleaning. Try using air pressure to clean. If not disassembling may be necessary to further look for problem. Could be rear bearing seized also. In any case don't use until you fix the problem or you'll burn it out.
How to thread a Juki DDW-122I
See Jiku Website. You can download the required manual by giving type of machine, model number etc.
Juki-Manuals (jukilanka.com)
There are more than 400 manuals on this site. You can find your required manual.
Juki manuals
1helpful
2answers
Juki DDL-555 engine starts smoking after a while
it would be a good idea since the machine made a banging noise & was smoking
to have it check to see why that happened to avoid any future damage to the machine
Smoke
MAYBE YOUR SAW HAS NOT ENOUGH POWER OR THE BLADE IS BAD.
Dec 18, 2011 • Saws
1helpful
Smoke out of sawzall
I don't think that it is only dirt. It could be the switch or possibly another electrical part causing the smoke. How does the saw run?? Can you look into the vents of the handle area and see it arcing excessively when running with no load, if so you have an electrical issue that would need to be fixed, Let me know if I can be of more assistance.
My coleman 18volt PMD8133XL drill smokes and has a burning smell when oressing triger
Hello, I hate when this happens to my tools. This could be a number of issues. I would think that the transistor that controls the motor speed is shot or the motor itself is loading the transistor causing the smoke, or the brushes internally of the motor are worn and causing the overheating, hence smoke. Is the unit new or well used?
Joe
2helpful
2helpful
Reduced RPM and smell smoke
Could be electrical problem, (brushes burnt, armature grounded or bearings starting to seize up) I don't think that I would use it till the problem is fixed. Could cause or create more expensive repair. Let me know and I will try and help
Smoking
Couple things I would look for first the condition of the blade do you see any buildup around the teeth like something has burnt on it. Also look into the area around the blade under the table (unplug saw first) to make sure that something hasn't dropped into it rubbing blade causing smoke. Also turn the blade by hand to make sure turning freely. The smoke could possibly be coming from a bearing. If it less than a year old Bosch has a pretty good warranty and you might look into that also. Let me know and I will dig deeper into it.
Clattering sound, then smoke
the clattering sound was probably a stone or something that was being bounced around by the rotating bush. It jammed which caused the belt to slip and cause the smoke you saw. You can probably get away with finding and clearing the jam but I would inspect the belt just to make sure.
Top Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Saw Expert? Answer questions, earn points and help others
