Question about curren Watches
How do i remove back of Curren watch m8310? needs battery. thanks
Posted by william j cross on
ray gallant
    Top Expert:
  • 66,956 Answers
IF IT HAS 4 LUG SLOTS IT UNSCREWS IF NOT IT WILL NEED PRIED OFF
Posted on Mar 05, 2020
Testimonial: "no 4 slots. it has tiny saw-tooth like teeth around the perimeter of the case back, suggesting it unscrews, but how?"
How to set date on a Curren M8146 watch
Please send me a this watch the I tell you how to set the date on this watch.
Oct 04, 2018 | curren Watches
How do I adjust the time on a Curren wrist watch?
Google (curren)(model)(manual) without parens for instructions.
Aug 17, 2018 | The Watches
Is there a manual for aCurren 8270 watch. I am not sure how the clip on the side works
Google (Curren)(8270)(manual) without parens to find out.
Jul 06, 2018 | The Watches
Curren manual
How do I set my Curren rose black watch
Oct 22, 2012 | Watches
The watch seems to stop when I wear it - fine timekeeper if not worn!
The only way that makes any sense is if there is something loose inside the watch possible the battery plate or battery are moving when you are moving. The back will need to be removed and the battery plate checked. You will need to have the watch checked at a jewelry store or watch repair shop. Thank you i hope this helps a little !!
Oct 24, 2011 | Jaeger-lecoultre Reverso Duoface 2711410...
I have a pocket watch i bought in paris but the battery ranout and i cant get the back off to get the battery out. what should i do?
Hi Josh, I do apologize for the inconvenience.Please try the below steps which should be helpful for you to remove the back of the watch and also replace the battery.
  1. Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
    (OR)
    Find the small groove on the back of the watch right above the hinge,place the tip of the screwdriver (the small kind used for the screws in glasses) into the groove and gently pry off the back of the watch.
  2. Remove the circular watch battery out of the back of the watch.
  3. Take the battery to any department store or watch store and purchase a new replacement battery.
  4. Insert the new battery into the back of the watch.
  5. Screw on or push on the back of the watch. Set the watch to the correct time.
The above should be of help for you to have the battery on the pocket watch replaced and have the watch working once again.Best wishes for your effort and thank you for your time and patience.
Nov 12, 2010 | Fossil VT2654 Pocketwatch
How can i tell a fake from authentic?
mcdevito75 here, Best Bet is to look for a small watch repair shop in your area, they can authenticate your Gucci watch for you. If you can, remove the back cover of your Gucci and record any and all numbers and other info off the watches movement itself then check online at Gucci.com. If your not familiar with watches, specially Gucci an expensive watch let a small watch repair shop remove the back cover and give you all info needed to authenticate the watch.
Oct 23, 2010 | Gucci 03665 Wrist Watch for Women
How iI open a casio 705 woman watch?
Thank you for contacting FixYa.
You will need:
  • A jeweler's screwdriver- Either flat head or Philips, depending on the model of watch.
    A cup or small box-This is to hold any screws.
  • How to change a Casio watch battery:
    1. Spread a cloth over your work area The cloth will help you avoid damaging the finish on your watch.
    2. If necessary, remove the watch band Removing the band gives you easier access to the back plate.
    3. Remove the back plate For some models this means using a screwdriver to gently pry it open, and others require removing screws. Keep small screws in a container to avoid losing them!
    4. Take note of the rubber seal Sometimes they need to be reinstalled in the same orientation. You might even want to use a marker to make a small "match mark" before removing it.
    5. Locate the battery It looks like a small metal button.
    6. Remove the battery You might need to loosen (not remove) a small screw and slide a latch out of the way. For other models, it's as simple as popping open a strap that is stretched across the cell.
    7. Install the new battery Make sure it's in the same orientation as the old one. They usually go in with the positive (+) side down.
    8. Perform a reset Do this by touching one tip of the tweezers to the AC contact, inside the watch, and the other tip to the back of the watch battery.
    9. Make sure the watch is working properly Carefully lift the watch to do this. Don't turn it over or the watch movement might fall out.
    10. Reassemble and seal the watch Perform steps one through four in reverse order to reassemble your watch.
    Best regards. Jewel
    Sep 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Need to change the battery on my fossil watch but can't seem to remove the back of the watch to do so
    good morning ! if your watch is waterfroop design that`s have a tread so if you want to open the case back you need a wrench or opener, but if your watch is snop in design you need a knife to open the case back,and change the battery,thank you,
    Aug 27, 2008 | Fossil Watches
    Watches Logo
    Top curren Watches Experts
    Ngoro
    ray gallant
    Tom Chichester
    Are you a curren Watch Expert? Answer questions, earn points and help others
