Question about Garden
How o make chainsaw run - Garden
Posted by mikewampler on
Saw dies after working for fifteen minutes
Could be a multitude of issues, I however suspect the carb is in need of adjustment. The chainsaw while operating under manufacturer specs runs between 900 degrees (F) and 1100 degrees (F) if the chainsaw exceeds 1100 (which after 15 minutes of use this is possible) the chainsaw quits or what is called a lean seizure, the piston swells and scores the cylinder walls. when the piston swells too much it seizes the chainsaw, after it cools down it the piston will shrink and the chainsaw will run again. Too many times and the piston will score the cylinder causing damage and space between the cylinder wall and the piston.
Oct 10, 2016 | Garden
Poulan chainsaw starts but won't stay running
Try choking it a little longer and it will warm up and should run
Jul 25, 2016 | Poulan Garden
Cant stay running
What to do if your chainsaw won't stay running?
arborist101.com/what-to-do-if-your-chainsaw-wont-stay-running/
Idle ports may be plugged or blocked - This is the small ports in the carburetor where the fuel passes through when in idle. ... Vent in the Fuel Cap is plugged - If the vents in the fuel caps are clogged the fuel becomes vacuum locked. ... Starting with the High Speed screw, turn it ...
Craftsman 16" Chainsaw Fix - Won't Run - Fixed! - YouTube
? 1:32
https://www.youtube.com/watch?v=aIUVQziXBPY
Jul 7, 2011 - Uploaded by BriggsRepair
Is this Craftsman 16" chainsaw broken? Hardly. Watch this carburetor fix and how it runs brand new!
Chainsaw won't stay running - DoItYourself.com Community Forums
www.doityourself.com/.../360759-chainsaw-wont-stay-running.html
Sep 20, 2008 - Chainsaw won't stay running. Craftsman 16" chainsaw, fuel/oil ratio 40:1. Saw is 10 years old, used once or twice a season. Last used in spring ... chainsaw wont stay running
Aug 1, 2015
Craftsman chainsaw won't stay running
Oct 30, 2010
Chain saw won't stay running
Oct 2, 2006
Poulan Chainsaw - starts but won't run
Apr 28, 2006
More results from www.doityourself.com
Why won't my chainsaw stay running? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 31, 2016 | Garden
Cant get enought gas
repair - What should I check if my chainsaw fails to start ...
diy.stackexchange.com/.../what-should-i-check-if-my-chainsaw-fails-to-s...
Feb 26, 2013 - Does anybody have any idea what I can do to get my chainsaw started?... Clean carburetor and fuel lines, especially if it may contain old fuel. ... that prevents it from generating enough current to sustain repeated firing of the spark plug as the engine turns. ... Your muffler is pluged up your saw can't exhaust.
Stihl Chainsaw - starts but won't run - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Aug 9, 2006 - Re-chocking (once until it kicks) gets it running again for another 20-30 seconds ... carb body was not letting enough gas through to contunue running the saw at full speed ..... MY STIHL 029 CHAIN SAW BLOWS GAS BACK OUT OF THE .....Can't imagine why shaking the saw around would keep it running. Chain saw won't start
Feb 8, 2012
homelite xl chainsaw
Sep 4, 2009
Husqvarna chainsaw wont start?? HELP
Oct 15, 2006
chainsaw starts then after few cuts shuts down
Mar 30, 2006
More results from forums2.gardenweb.com
chainsaw won't start - any ideas? [Archive] - Straight Dxxe ...
boards.straightdope.com > ... > Main > General Questions
21 posts - ‎11 authors
As the chain stretches for McCulloch chainsaw Titan 7
a couple things will cause a chain to stretch running it to tight running low on oil a dull chain over heats it
Sep 20, 2012 | Garden
I have a 14" Woodshark Poulan chainsaw. I put in
Poulan Chainsaws are pretty well all powered by two stroke engines. My best guess is that you have the fuel mixture incorrect (it should be a 1:40 ratio of oil to gas). if the fuel mixture is not the problem then your choke is messed up. If you haven't tried already try and find the sweet spot in the choke where it will run.
Mar 04, 2011 | Poulan 14" Chainsaw
How to adjust a mcculloch 610 chainsaw carberator
there are two screws on the card of youy chainsaw one is the slow running jet the other is the full throttle jet start up saw run it till its hot adjust slow running jet first till saw ticks over ok then adjust fast running jet till you have full throttle,, start with both screw turned in to one and a half turns then adjust from there
Mar 28, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
Homelite xl chainsaw revved up & quit and won't start now
I suspect you have a fuel delivery problem or a dirty carburetor. As a chain saw runs out of fuel they often revv slightly (running lean). HTH
Lou
Oct 06, 2009 | Garden
Stihl ms310 chainsaw will only run on choke
You actually need the adjustment tool,looks lie a small screwdriver with a smal socket at the end of it.
Jun 02, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
