If you have single handle facute one bad cartridge in the system may be acting like a mixing valve and allowing cold water to mix with hot not allowing water to get hot enough .
Limit message is when the output water set temperature can not be reached, this is normally when the incoming hot water to the shower unit is not sufficiently hot. Service code 20 is something else inside the unit that is faulty, it could be a number of faults. Try reset Power down unit and re-start, it will either say Wait or Priming, after that it should restart, hopefully it will work. If not, you could have a internal fault with: The mixer valve/motor, the flow control valve or motor, the flow sensor. If you have hot water from other taps, then the mixer valve/motor is the most likely fault. If you only have cold water only from the shower head with limit message it could be the Hot solenoid controlled valve is faulty. Good luck as there are no spares available!
The thermostatic stop is set too low.
Havent set a grohe before but most other thermostatic shower valves work similar.
pull off the handle(however a grohe handle comes off . . ) there should be a notched ring or stop which keeps the handle from going all the way hot. pull out the ring and turn it a few teeth hotter put back and reinstall handle try water temp and adjust again if necessary.
Do you mean the other faucets in the house are hot and only the shower is warm?
If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back.
maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
