SOURCE: Stuck in power save mode
Followed the directions of redlegs1, posted 12/26/2007. It didn't work the first time, but sure did on the second attempt. Thanks redlegs1, you're no apprentice my friend!
SOURCE: stuck in power save mode
Have you have selected the input you are using? You can switch between analog and digital input. The monitor would stay in power save if the input other than the one you are using is selected.
I believe the default input is DVI. Are you using VGA?
In the menu, under advanced, you can select the input.
SOURCE: Dell Inspiron 530 power save mode issues
Volto is wrong.
http://support.dell.com/support/edocs/systems/inspd530/EN/OM/solving.htm#wp999606
SOURCE: Turning Off Power Save Mode on Dell All in One 948 Red Printer
you can find it from the printer properties tab in the print window
SOURCE: Dell E173FP stuck in power save mode
Just had the same problem... what worked for me was simple. Unplug the cable from the monitor, hit the power button a few times until Dell screen poped up with a few color bars because it knew it was no longer connected to a PC. Then plugged the cable back in and all was fixed.
you meant
Dell P2411H Black 24" 5ms Height,Swivel & Tilt Adjustable LED Backlight LCD Monitor w/USB Ports 250 cd/m2 1000:1
the answer is YOU CAN NOT do that in the monitor only in the PC, OK.
buttttt
in Control panel + power settings
on all PCs with windows
no PC told no OS told
all from Butttt down is me guessing you blind.
in Linux, or CHROME OS or others ,all a different answer
NO PC told. at all.
we can not guess PCs nor the OS.
oops 2010 monitor the magic date 2010
is the transition year, from CCLF monitors to real LED. (bingo LED)
that means some have sleep timer inside the monitor, push OSD menu button on monitor
turn that off for sure if seen
this Monitor is LED backlamped,
and has no internal timer
if the PC goes to sleep the monitor power lED goes to AMBER to tell that fact.
I read your manual to be sure 2010 is must
wow has Dell monitor diagnostic inside.
very nice that, Dell is great.
a working w10 (is it) PC will not get stuck
all you do is hit any key on the keyboard
and the PC ends sleep mode and can be slow if using nasty hibernate mode.
if this fails that means
the USB ports are dead. wire keyboards
The controls for sleep are deep but in one place per above.
make sure USB ports are not dead in device manager. and drivers good there, no errors.
then make sure power settings are set correctly. make sure wake on USB is turned on not off.
a mouse too (wired) can wake up a PC tool
clicked.
if PC is old and upgraded to w10 many of those the USB ports are born dead.
NO PC told at all nor OS
learn this 1 thing
the PC GPU port if it goes dead (sleep)
the monitor sees that and the monitor goes to sleep (by laws in USA, and Energy star )
that is how it works.
so the PC side is CAUSE !
if the cableS did not faLL OFF pc THAT IS.
