try to reset your computer by disconnecting the positive cable on battery for 5mins if lights go off @ they should, run get that sticker before the cops get you!!!!!!
because the power required for lights and radio are very less. but for starting the engine is more becaause ot needs to turn the engine. please check the voltage it should be 12-14 volts.
if it doesnt have this much power charge the battery and check start it wil start.
the light reminds you to service the engine . A mechanic can or you can turn the light out by disconnecting the Battery.this also causes memory loss in your Radio .
Have your saturns battery checked out by load testing it. The charging system as well. Most auto part dealers will do this for you....Kragens, Napa, Autozone...Inspect and clean battery cables and terminals, replace as needed. Good luck..i hope this helps, please rate me a fixya.
This sounds like a plugged evap valve. Try opening the gas cap when this happens. If the evap system is malfunctioning, it will use gas, but will not let air back in to replace the liquid leaving the tank thus collapsing the tank and cutting off fuel. It then takes a while to break the vacuum in the tank. If the car starts right away when you open the gas cap, have your evap system serviced by a professional. Another quick diagnosis is to take a look at the fuel tank. If it has been collapsed there will be small creases in it.
