Get the manual? on it? yet?
RTM . typed the number wrong ,
kenwood KGC4300 equalizer
WANT DIN PLUG PINPUT. on
IS THIS A CAR RADIO AND YOU LEFT OFF THE KGC4300
THAT IT/? 35 years old today, that? 1985 made !
Be nice for you to first tell what it is. how used, in car? home stereo or what?
who hard to find, the KGC4300 , DIN cable lost.
# of EQ Bands: 5 - Equalizer Features: Subwoofer Output, Fader Control
yes it has a DIN plug cable set with it , new but you lost it/
Id trash it but
the service manual is here.
https://www.ebay.com/itm/Kenwood-kgc-4300-service-manual-original-repair-book-stereo-car-radio-eq-amp/123728129201?hash=item1ccec56cb1:g:zF4AAOSwkm9az4c7
the only other 2 ways to fix this is buy the cable and last find a rare schematic of this EQ. boxl.
here is the schematic.
https://www.user-manuals.com/circuit-diagrams-KENWOOD-KGC4300.html
SOURCE: Kenwood KA-72B Stereo Receiver HELP NEEDED.
Why not plug the cassette directly into the CD recorder? Are they trying to achieve some eqalization change? If not, then this should work. It's all analog at tape level.
SOURCE: din pin wiring
depending on how bad the current plug is what you can do is cut the plug down the middle (about 1/2" from the the tips of the pins) and what that will do is put you inside the plug just behind the solder points on the pins and from there ou should be able to indentify which colored wire went where and then make a diagram on paper. If the plug is not too bad off right now i would cut the cable behind the plug and trace whatever wires are still good to the tips of the pins and write their locations down before cutting the plug. Try to cut the plug as clean as possible using something like a dremel rotary tool works well, you may have to pause in cutting if the plastic starts melting too much do to heat from friction.
SOURCE: USER MANUAL FOR A KENWOOD DPX 5000 DOUBLE DIN CAR STEREO
hi
i want rest code kenwood dpx 5000 car tape plz reply mee with master rest code
thanksssssssssssss
