Question about Home
My well has its normal 40 psi, problem is the pressure will drop when taking a shower our shower is on the second floor. It can also lose pressure on something as simple as flushing a toilet. When this happens I go in the basement flip off the electrical switch to the pump wait a couple seconds flip it back on and the pressure returns no problem until it randomly happens again. I’ve had the pressure tank replaced recently a new pressure switch and the fittings replaced feeding the pressure tank from outside. This has been an issue since the pump was new when we bought the house. Help please.
Posted by Eric Dameworth on
Vernon Taylor
  • 6,843 Answers
I am certainly not an expert but your description does suggest your well pump could be sitting on or in sand or other loose sediment that is being drawn to the intake gauze when the water flow is high, restricting the flow and therefore cutting the pressure.
Switching off for a few seconds would allow the sediment or whatever it is to settle back and restore performance until high flow is needed again.
Scale down the problem to the size of a vehicle fuel system and the most common cause of the same symptoms apart from water in the fuel tank is something like a piece of rag or especially a plastic bag in the tank.
Posted on Feb 29, 2020
1 Related Answer
jimmy
  • 409 Answers
SOURCE: Lots of water on basement floor at pressure tank.
sounds like the bladder tank at the well is ruptured this will cause pressure surge, and pump short cycling, and needs to be replaced asap.
Posted on Mar 29, 2010
Will not start first try but will start
If the engine starts and run good on second or third time. Install fuel pressure gauge and run the engine for a wile and turn OFF. the fuel on running engine will be 60-65 PSI. After 5 min. will drop to 40 PSI.If continue to drop to 0 PSI suspect fuel pressure regulator or fuel pump.
Apr 07, 2014 | Cadillac DeVille Cars & Trucks
Water temperature fluctuates with tankless
Have you ever tried to pump water for a fountain... It is so tough and you need larger and larger pumps to get it to go 7 feet high to let's say 10 feet high. Having the on demand water heater in the attic dramatically drops it's pressure. It's best to feed it with a 1 inch or at least 3/4 inch pipe downstairs before it splits the hot and the cold to get the best pressure everywhere then the least pressure will be when it reaches the 2nd floor. but the heater won't cut out because the pressure it even greater downstairs.
Nov 30, 2013 | Rinnai Water Heaters
2001 Chevy express van oil pressure
Did you verify oil pressure with an oil pressure gauge besides the one on the instrument cluster?
Aug 21, 2012 | Cars & Trucks
I have 70 psi water pressure at my street meter but only 50 psi or less at my house which is not more than 30 feet away with less than a 4 foot rise. What would cause such a drop in pressure?
Find the pressure regulator and adjust accordingly. It can be found between the street pressure gauge and the hom's pressure gauge. It is usually adjusts by turning a screw.
Jan 23, 2011 | Sterling Plumbing 1500D-31S VISTA PIVOT...
How to Maintain a Bike's Tire Pressure for Good Performance?
Buy a good floor pump with a gauge (see "How to Buy a Bike Pump," under Related eHows). A small, frame-mounted pump is useful only for roadside repairs.
Understand that it's normal for most tires to lose up to 10 pounds per square inch (psi) per week. This does not mean you have a slow leak.
Look on the tire's sidewall for tire pressure recommendations. Don't exceed the maximum tire pressure listed.
Inflate your mountain bike's tires to 40 psi for dirt riding. You may wish to inflate your tires to 50 to 60 psi for city riding.
Inflate your road bike's tires to 100 psi for road riding. Some road tires have much higher psi ratings. However, 100 psi will provide a good mix of performance and comfort.
Inflate your hybrid bike's tires to 60 to 70 psi for city riding.
Check your tire pressure before every ride
Dec 21, 2010 | Cycling
Mar 28, 2010 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
My hayward c17502 is running 40 psi. is this normal?
Sounds high. Take cartridge out, put top back on and run. Check pressure. If cartridge is good, pressure should remain close to the same with or without it . If pressure drops way down replace cartridge.
Mar 17, 2010 | Hayward SAND FILTER, PRO SERIES
Lose oil pressure after motor warmsup 1992 ford probe
How low does the pressure get? It only takes 4 psi to keep an engine lubricated. The pressure will drop off as the engine get to operating temperature. This is normal. As long as the pressure climbs instantly when you accelerate you're ok.
Mar 01, 2010 | 1992 Ford Probe
I have oil pressure until i stop , then it drops to below 10 psi
Increase the viscocity of your oil. If you're using 10W30, go to 10W40. If you're using 10W40 switch to 20W50. Don't use single weight oil.
Sep 19, 2009 | 1998 Jeep Wrangler
Sudden High and Low Oil Pressures
yes it might work if u flush it, give it a try
May 27, 2009 | 2000 Dodge Ram 1500 Truck
Home Logo
85 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
