Question about Aiwa Audio Players & Recorders
SOURCE: Aiwa NSX-TR77
Well Jamez sounds like you have eather blown the soeakers or the output IC's inside the unit. If you have a meter you can simply disconnect the speakers and test the resistance of the speakers with an ohm meter. If you dont have an ohm meter then you can connect them up to another stereo or have them and the unit tested at a repair center. Sorry not really any serviceable parts in these systems. Good Luck
Posted on May 12, 2006
SOURCE: Just a question on specs for Aiwa NSX-5200 system
Hello I have had a look on the internet and found this for you it should let you download the user manual for free, good luck you should find out your specs
www.devicemanuals.com/company/AIWA-manuals-page9.html - 49k -
djdizzys
Posted on Feb 20, 2008
SOURCE: It is possible to connect a "AIWA NSX V70" as a
Use VIDEO/AUX instead. MIC is for the smaller input signal that a microphone would typically produce.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-NSX-V70-manual/id/1076ci461/t/2/
Use your PC soundcard controls to adjust the output to something useable (max?).
Posted on Apr 30, 2011
SOURCE: Aiwa NSX-V70 Cassette deck Belt?
u can get from ebay.de website many type belts for sepcaly aiwa nsx seriess,all total cost 25 euro
Posted on Oct 10, 2012
SOURCE: aiwa nsx-999 display and cd changer problems
I had a similar problem with my NSX-999. For CD, u need to clean the laser or buy a new cd-laser pickup KSS-210A.
For dim display, replace capacitor C107 and C108 in the mainboard if u know how or take to a repair shop and ask them to replace those two capacitors. It soled my problem
Posted on Jun 29, 2013
Sep 02, 2018 | Aiwa Audio Players & Recorders
Nov 08, 2016 | Aiwa Audio Players & Recorders
Mar 14, 2012 | Aiwa Audio Players & Recorders
Apr 30, 2011 | Aiwa NSX-AJ300 CD Shelf System
1 Connect the front speakers.
Connect the right front speaker to the SPEAKERS R terminals and place it on the right side of the unit. Connect the left to the SPEAKERS L terminals and place it on the left side.The speaker cords with the white stripes go to the + terminals.
Jan 15, 2011 | Aiwa NSX-A777 Shelf System
Dec 15, 2010 | Aiwa Audio Players & Recorders
Oct 21, 2010 | Aiwa NSX-MTD9 Shelf System
Jul 12, 2009 | Aiwa NSX-DS55 CD Shelf System
Dec 27, 2008 | Aiwa NSX-2700 Shelf System
May 11, 2006 | Aiwa NSX-TR77 CD Shelf System
80 people viewed this question
