Question about The Computers & Internet
Adjusting the angle on the monitor - The Computers & Internet
Posted by Keith Doren on
Larry Ng
  • The Master
  • 6,039 Answers
No PC told
no monitor make or model told.
but all monitors made 99% you can buy a monitor stand and more to get any angle you want. (I have pro grade stand on mine) 100mm.x100mm VESA mount.
mine goes up/down , and tilt, and even 90degree turned.
Posted on Feb 29, 2020
Asus 19inch LCD monitor keeps auto adjusting and turn off after 2secs. . i do reset it . . nothing happens. .it keeps auto adjusting itself repeatedly . . pls help me
The Auto knob maybe mechanically stuck or the internal switch may be defective. Try pressing the Auto switch firmly 10-15 times,If monitor works now the switch is defective and needs replacement. Do rate the solution.
Samir
How do I adjust the angle of my HP LE1901 monitor?
mcdevito75 here, Most Monitors will angle some what for ease of viewing by simply angleing by hand pressure, secure your monitor at the 3 and 9 O"clock position with your hands and see if this helps. Look at the base and back of your monitor for any levers, or knobs to loosen so you can adjust the angle. Remember you may not be able to angle your monitor and if not, you may have to use a better chair.
Can I change the angle of my viewsonic screen
Here is what you can do ergonomically;
Height adjustment range 8.1cm / 3.2", tilt, swivel range 360º
So, yes you can tilt the monitor's angle, but if you are asking about the viewing angles then no you cannot.
2helpful
Desktop starts normally. 152s too dark to see. only viible with desklight shone on angle. menu adjustment doesnt solve problem. any fix or is monitor buggered?
Yes, there is one solution.
Open the monitor case, then see for Flyback transformer ( with cable attached to the CRT Tube with rubber cap).Then using screw driver (+ or - ), adjust the screen positions until you get the best brightness.Usually it's on the lower part of Flyback transformer, on the upper side, it's used to adjust the focus.
It has a line above the screen
While stripe line? Adjust the angle, trapezoidal setting son your monitor, the Vertical alignment and Horizontal alignment, if you do this correctly but have the same problem, your monitor is defective
4helpful
How to angle the monitor
I have Model X203H & had the same problem. The support CD explained how to adjust the monitor:
Screen position adjustment
To optimize the viewing position, you can adjust the monitor tilt by using
both of your hands to hold the edges of the monitor.
The monitor can be adjusted to 15 degrees up or 5 degrees down.
How to adjust the monitor
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00845847&dlc=en&product=3351967
try clicking on it first
copy & paste this in your address bar, hit enter, this should take you to a page with descriptions on how to do it. biigg53566
Screen Tilt
Mine did the same thing. If it is not aligned properly this will happen. Take the kit off from around the unit. Then tell it to go to what ever screen setting you want. If it works with the kit removed this is your problem.
Screen Angle
You can change the screen with the help of adjust buttons given on your monitor.
Open Questions:
Computers & Internet Logo
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
EKASYS IT SERVICES
EKASYS IT SERVICES
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
