I checked the existing Q&A regarding this dishwasher and found the answer. Thanks to the people who had already addressed this issue . . . it helped me, too!
When the clean light flashes, it indicates a problem with the heating element or that the control board isn't getting the change in water temperature information in the expected period of time. Sometimes this is caused by a problem with the thermistor or thermostat. It could also be caused by a problem with the door switch or motor. Try cleaning the area around the latch and draining the washer after putting water in the tub. After that inspect the element for pitting or discoloration. Replace it if it is damaged. Check the resistance across the thermistor to ensure that the part is good. Check the wiring between the motor, thermostat, and heating element to the control panel for continuity and replace if there is a problem. If the rest of the parts are good, replace the control board.
The parts list, diagram and pricing are available here: https://www.searspartsdirect.com/model/5umy9dy54i-000582/kenmore-66517033401-dishwasher-parts . Another parts list is available here: https://www.repairclinic.com/ProductDetail/939926 .
I hope this helps.
