Computers & Internet Logo
Question about The Computers & Internet
What's the weight of the Benq q24w5 monitor only? Without the stand? I have to attach it to an arm. Thanks!
Posted by andrea canzonetta on
Larry Ng
    Top Expert:
  • The Master
  • 9,723 Answers
Use a scale, use postal scale, ask friends for one to use.
gee easy, no?
or google the manual
Benq q24w5,
typed wrong BENQ is one word
then the model is (that too typed wrong by you, ouch)
FP241W
goggle 1st hit shows, 10.6 kg or 23.3 pounds, (USA imperial)
sorry the books do not cover stand off weights. use a scale or subtract say 3lbs. to 20. (by seamans eye)
Posted on Feb 29, 2020
HOW TO ASSEMBLE WEIGHT BENCH ?
Lay out all the pieces and check the instructions to make sure everything has been included with your weight bench. Attach the cross brace to the left upright beam and repeat the process for the right upright beam. Tighten them together with carriage bolts and set the backrest adjustment bar onto a slot on the upright beams.
Connect the main seat support beam to the cross brace with two carriage bolts, two washers, and two nuts. Do not completely tighten the nuts in place. Attach the main support beam to the front post with Allen bolts and washers. Connect the diagonal support beam to the front post in the same manner. Attach the other end of the diagonal support to the main seat support beam.
Place the arm curl stand in the front post and secure it in place with a lock knob. Tighten it down completely. Connect the leg developer post to the bracket on the front side of the front post. Attach the arm curl handle to the open bracket on the leg developer with an L-shaped lock pin.
71hekan4jtl._sl1500_-qw1ux3sfzoyydmyeq2qu2kbl-2-0.jpg Attach the bracket supports to both ends of the pivot arm of the support beam and lay the other ends on the backrest adjustment Pull up bar. Connect the backrest board to the supports with four hex bolts. Attach the seat pad with four hex bolts onto the main seat support.
Secure the preacher pad arm to the curl stand with two Allen bolts. Put two foam tubes into the leg developer halfway through the holes and attach the four foam rolls onto the ends of the tubes.
Hp f1905 drops down
Contact HP by phone and they should help you getting another stand for your monitor.
1helpful
BenQ Q24W5 LCD monitor circuit diagram
HI.............
Repairing BenQ 17′ LCD Monitor
I came across a common fault problem in BenQ 17′ LCD Monitor. The problem is have power but no display. Once you has opened the LCD cover, check the pico fuse for open circuit (very common), the push pull transistors C5707 for short circuit and the Buck royer circuit p-channel fet FQU11P06 also for short circuit too. For your information, if you can't get the FQU11p06 you can always use FU9024N as a replacement. Resolder all the high voltage transformer pins and replace the components above and I'm sure you will bring back the life of this BenQ 17′ LCD Monitor.
You may go to this fairchild semiconductor website to download the spec of the FQU11P06 P-channel FET.
http://www.fairchildsemi.com/ds/FQ/FQU11P06.pdf
GOOD LUCK.............
Repair BenQ Q24W5 monitor
HIIIIIIIII...................
3answers
Hi we have samsung lcd 22 inchess.. we need to fix it to wall and there is no backside stand .. how can we get the stand
Most electronic stores sell wall mounting brackets. There are several types. one mounts the LCD screen flat to the wall with a limited range of tilt. Another type mount the LCD screen on an arm that allows tilt and swing movements.
2answers
Monitor stand screws
More likely to be metric M4 screws, 1/2" will more likely to be long enough.
3helpful
How do you remove the stand from a BenQ 767?
remove screws either side where stand go into back of monitor.
then slide stand toward bottom of monitor and it should slide out
I want to attach my St2310 monitor to a support
There is a Bracket for sell on ebay the item nubeItem number: 200519763403
Item number: 200519763403The item number is: 200519763403
1helpful
3answers
Monitor stand
I have one or two nice used Original ones available.
Where are you located ?
email [email protected] if you want pictures and costs
Top The Computers & Internet Experts
NADARK
NADARK
A Kisling
A Kisling
nexrad_chris
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
