Question about Alpine Car Audio & Video
Illustration of RCA Jack's in back of be Alpine 3321
Posted by Glenn Wain on
brian williams
    Genius:
  • 1,866 Answers
What's your question?
Posted on Feb 28, 2020
3helpful
IPod connexion to Alpine CVA 1003R
Yes it can work. but you can only use the audio feature of your iPod and not the video. Try to look for a cable with RCA (red/white) connector and a stereo jack on the other end. Connect the RCA cable where the cd changer connects and the stereo jack to your iPod.
^_^
One rca jack for subwoofer (jvc kd-avx44)
I run this set up im runng a 1000 rms Alpine and 2 alpine type S and everys good
Unsure how to connect up external connections need to see illustration for these connections as i do not have any info'
tape decks has a line out and line in RCA jack at the rear this is for the amplifier connection. line out should be connect to amplifier line in jack. Tape deck has also RCA jack input for Radio or Tuner, Phono, VCR, or CD, and Aux. You can input the audio out R&L to the selected input above.
3helpful
2answers
Haveing trouble hearing sound when I have my IPod connected
You need a AI Net cable or Speed Cable... It plugs into the back of the radio (looks like a circle with holes), and the other end can have a "Y" plug (headphone jack and iPod flat jack). The headphone jack for sound, the flat jack to charge he iPod while listening. I just bought mine on Crutchfield.com for $29.99. With the discount code: 3A156 you can get standard shipping free. The item # is: 127ICALPA and it's named "PAC iPod Adapter for Alpine".
1helpful
Want to know if I can use the line-level inputs from the CD Chgr
Your alpine unit is the old "M-BUS" the other adapter you are talking about is an "AI-BUS" adapter. (Hence the model numbers beginning with CD"M" or CD"A" ...)
Look for an Alpine M-Bus to RCA Input adapter.
heres one on eay for less than 10.00 including shipping.
http://cgi.ebay.com/For-Alpine-M-Bus-to-stereo-RCA-adapter-cord-cable-8-pin_W0QQitemZ310117370938QQihZ021QQcategoryZ60208QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
2helpful
I have a Alpine CDA-9830. It has a AUX setting and so I was wondering if I can connect an ipod to it? I cant seem to find any input for a cable. I looked online at the manual, but it didnt really answer my...
Hey Guys,
This is the part you need..its an adapter for Alpine stereo..its called the ainet to rca.. then all you need to do is get a stereo jack cable to rca and plug the stereo jack cable in to the ipod and rca's in to the adapter..it plugs on left side of back of the unit if you are looking at it from behind
KCA-121B
cheers
2answers
Ipod connection instruction
you can get a set of phono leads with a jack on just one end?plug that in to the back of the head unit (depending on your pre out options and aux option) then plug it straight in to you ipod.
hope that helps?
2answers
Aux or line in
No line in or aux inputs. Installation Manual is here; http://vault.alpine-usa.com/products/documents/OM_CDA-W550.PDF Best of Luck.
RCA inputs bad
If you got the exact same ones, you should be able to simply pit them back into the same holes. if you did not get the same ones, look at the open holes, two should be connected together, and two are separate. Hook the two that are connected together to the ground part of the jacks, and the middle connections of the jack to the other two holes. if this does not make any since, send a picture of the jacks and the board so we can look at it for you. Good Luck
Car Audio & Video Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
