Question about Sharp Televison & Video
How to fix sharp tv Lc-80LE632u two long five short blinks
Posted by Santiago Romero on
    Top Expert:
  • Sharp Master
  • 76,625 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Posted on Feb 28, 2020
5 Related Answers
Anonymous
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
Anonymous
SOURCE: Blinking Lights
This didn't work for me but maybe it will for you. I had the exact same problem. The 5 amber lights indicates a problem with the print head. If you take out all of the cartridges, you can easily pop out the printhead, just slips right out. take some alcohol(rubbing, Not Jack Daniels) and cue-tips and clean the heck out of the contacts on the bottom of the printhead.
Good luck.
DC
Posted on Jul 28, 2009
Chi Chu
  • 8457 Answers
SOURCE: sharp LC-26d4u tv won't turn on/power light is off
Check ur power source,unplug replug if not work,Ur tv power board ic inverter it dead needed to be change.
Posted on Aug 17, 2009
Anonymous
  • 41 Answers
SOURCE: Blinking power and opc leds on front of unit
From the information you have provided failed capacitors in the power supply is likely causing the problem. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. The repair should cost about $250 if carried into a TV repair shop. A small TV repair shop will often charge less than a large repair facility.
Posted on Feb 25, 2010
Anonymous
SOURCE: I need a diagram for lcd tv Sharp LC-26SB14U.
I have a sharp LCD (LC-26SB14U) which I purchased one year ago and today the sound stop working as I was watching the olympics. Any idea how to fix this problem as the warranty is only good for a year.
Thanks, Bob
Posted on Feb 27, 2010
I have a Sharp TV Model:LC-80LE632U S/N:2128728173 that is getting a 1S+1F Blink Code
http://homenol.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Why tv sharp lc-80le632u when its starts it appear this blinking error "Power supply error 2 D+3.3V error"
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
HAVE AN BLINKING CODE OF 2 SHORT 3 LONG UNIT ITSELF MAKES A (POWER) CLICKING NOISE WHEN I TURN ON IS THIS SYMPTOMS OF A T-CON BOARD REPLACEMENT OR PERHAPS A POWER DIST. PROBLEM
Sharp Aquos LC-52E810UN does not turn on, front bezel indication light only blinks
Transformers fail on your power supply board. Go to the Sharp website put the model number in and serial number and in order and you can order a replacement parts. You can find out how to replace it via YouTube it's not as hard as you think
6helpful
4answers
Televison & Video Logo
Top Sharp Televison & Video Experts
 Grubhead
Grubhead
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
