SPLENDIDE 2000 S. My question, machine will not work. Got in in used RV. It worked great 2 times and quit in the middle of the 3rd use. Drum can be turned by hand easily. Makes no noise.
I have a splendide 2000 / WD802 pre m with round power buttons. It came with a used RV I bought. Everything would work on it except the drum wouldn't spin at all. After some research and messing around with it I was able to fix it! You remove the back panel and in the bottom left corner there is a white control module chip board mounted in by two screws. Remove the two screws from the back for access to fix it. Now the top plug on pin 1 and 2 shoud have 2 white wires connected to pin 1 and one baby blue wire connected to pin 2. I jumped these 2 pins together with a small length of wire and now our machine spins and works great! Be sure to used at least 6 inches of wire at least as thick as the rest of the wires and make sure that it is well connected. I recommend you take the crimps off the blue and white wires and re crimp them with the jumper wire crimped as well. If you don't have a good connection with a long enough wire it will get hot and possibly catch fire so it is very important to do this correctly. I hope this helps someone!!
I have a splendide 2000 / WD802 pre m with round power buttons. It came with a used RV I bought. Everything would work on it except the drum wouldn't spin at all. After some research and messing around with it I was able to fix it! You remove the back panel and in the bottom left corner there is a white control module chip board mounted in by two screws. Remove the two screws from the back for access to fix it. Now the top plug on pin 1 and 2 shoud have 2 white wires connected to pin 1 and one baby blue wire connected to pin 2. I jumped these 2 pins together with a small length of wire and now our machine spins and works great! Be sure to use at least 6 inches of wire at least as thick as the rest of the wires and make sure that it is well connected. I recommend you take the crimps off the blue and white wires and re crimp them with the jumper wire crimped as well or solder the connection. If you don't have a good connection with a long enough wire it will get hot and possibly catch fire so it is very important to do this correctly. I hope this helps someone!!
Use 2.5" plastic pipe & elbow to replace aluminum elbow & hose with spring inside. Air velocity is higher, lint blows out without collecting. I used wood router to remove part of exhaust connector on rear of dryer to better fit elbow. Elbow interior was smoothed to prevent lint sticking. Elbow was mounted with silicone sealant and 2 screws. Pipe was glued to elbow as normal glued pipe connection. Pipe end was cut even with side of dryer. After Spendide was installed in RV, a union was stuck in from outside RV. Union slides on to pipe without sealant so Splendide can be removed from RV. Union better fills outside vent fitting than bare 2.5" plastic pipe. Temporary seal aroung union was made of urethane foam scraps, common shipping stuff from a computer monitor box. After 2 years of temporary, the foam is now considered permanent. Original problem was constant lint problems in hose and slow drying. With pipe, not hose, lint is rarely cleaned and drying is much faster.
