Question about Humminbird Boating
Humminbird matrix 17 says transducer not connected and wax is leaking from transducer but voltage is good
Posted by Skyla Mitchell on
Andrew Taylor
    Top Expert:
  • Humminbird Master
  • 34,000 Answers
If its under warranty, send it back. They will say you grounded it or hit log. If not, buy a new one. You can't fix them.
Posted on Feb 26, 2020
Says no transducer connected and is in simulator mode. How do I get out of simulator mode?
the manual is here
http://www.humminbird.com/Category/Support/Product-Manuals/
I had this unit but gave it away recently. From memory, you just need to connect the transducer and make sure the transducer is in water. If not, it reverts to Demo Mode.
Aug 20, 2015 | Humminbird Piranhamax 170
Transducer leaking wax and fish finder say,s low voltage with two new battery,s
you have a bad transducer.. its a direct short if its leaking anything getting way to hot
Oct 03, 2013 | Humminbird Matrix 97 Combo Fish Finder And...
Temperature readout wrong
Hi, I'm assuming the transducer is in the water when you obtain tthese high readings, if so the transducer is likely faulty. regards Phil
May 30, 2012 | Humminbird Matrix 17 GPS Receiver
I just bought a used boat with a Humminbird 160 fish finder on it but, the only thing that shows up on the screen is the temperature, NO DEPTH and NO FISH, is there a setting i need to set as i am clueless...
Check to make sure the transducer is hooked up correctly, and check the actual transducer for signs of damage. Transducers are fragile, and a good whack can break the crystal inside. For more troubleshooting, here is a helpful link with the Owners Manual for your Humminbird.
http://store.humminbird.com/media/document/PiranhaMAX_150-160-170-180-190c.pdf
Aug 29, 2011 | Boating
I get an error msg that the transducer is not connected. How can I check idf the transducer is faulty
If you can find someone with a Humminbird that has the same pin configuration on the transducer cable, switch yours out and put the transducer in a bucket of water to see if it works. Otherwise, make sure the cable at the plotter end is firmly placed in the socket, and that no pins got bent in the past. Some of these models came with a metal clip that holds the end of the cable(s) tight to the plotter and is held tight by the mounting bracket screws.
Aug 28, 2011 | Humminbird Matrix 97 Combo Fish Finder And...
I have a Humminbird 565 that is about 3 years old and the end of the transducer has opened up and the sealant has all leaked out. I also have and older one that is doing the same thing. What's up with...
I have no idea, I use these same ones and havve several mounted and they are used both in summer and winter, never had one leak. I also looked up these and did not see where there were any issues with this problem. I suggest you call Humminbird and talk to them, they are usually very helpful.
Toll-free: 1-800-633-1468
Monday - Friday
8:00am - 4:30pm CST
Mar 04, 2011 | Humminbird Fishfinder 565 With Transom...
Hi I live in NZ and have a Humminbird 383c GPS Chartplottter which was purchased in the US. approx 2 years ago.It has a transom mounted transducer which I mounted in a piece of plastic pipe, epoxied in the...
Don,
We would recommend that you replace the transducer (if you want to keep the transducer inside the hull you may use the
XP 9 20 T with temperature and you can use epoxy to mount the transducer) If you want to keep in the compartment you have created you may want to just put water in the compartment with the transducer so its not shooting through the air.
If you have any other questions please email customer service at [email protected]
Thank you,
Deborah
Humminbird Customer Service
Jan 12, 2011 | Humminbird XNT Transducers XNT 9 20 T ...
When powering up[on land] it says transducer not connected,checked cable and connections.It use to work maybe went bad? Humminbird Matrix 10
Disconnect cable from back of unit clean the pin connections on the unit and on the cable. If rusty clean with Corrosion X are WD
IF it doesnt work replace cable Jim OMC Retired Mech
Jul 05, 2009 | Humminbird Matrix 12 Fishing System
Boating Logo
100 people viewed this question
Top Humminbird Boating Experts
Mike
ray gallant
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
