Question about Frigidaire Washing Machines
Both my Frigidaire affinity washer and dryer are stuck on pause. I’ve tried pushing every combo of buttons on the machine. The start and cancel button are the same so that option doesn’t work. Please help
Posted by Melissa Johnson on
Leroy Elliott
    Fixya-Fanatic:
    Visited the website for 90 consecutive days.
  • Frigidaire Master
  • 425 Answers
HOLD THE LOCK BUTTON FOR 10 SECONDS
Posted on Feb 25, 2020
5 Related Answers
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
Posted on May 21, 2008
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: machine stuck on pause/err
un plug the washer for 5 minutes and re try
Posted on Jun 03, 2008
Anonymous
  • 639 Answers
SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 25, 2008
Anonymous
SOURCE: Frigidaire Front Loading Washer, ATF6000ES stuck on pause mode - HELP!
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Posted on Jan 10, 2009
Anonymous
  • 57 Answers
SOURCE: frigidaire affinity dryer makes buzzing noise when
your motor is out you need to replace it
Posted on Mar 04, 2009
Washer states sensing with a buzz sound?
Hello keisha, thank you for your post!
I understand that your Frigidaire washer is making a buzzing sound until the cancel or start button has been pushed. It sounds like it could be a possible issue within the door either not being fully closed or it could be a defective switch. I would recommend resetting your appliance which can be done by disconnecting power to the appliance for roughly ten minutes. Please comment back if that did not help correct the issue. -Matt
Sep 05, 2014 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire dyer comes on then the pause message appears. These are new appliances.
Hello barbarada180 - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Jan 02, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
How do you ge codes on a electrolux front laod dryer?
* Wake the washer by pressing any button. * Wait 5 seconds. * Press and hold the Start and Pause/Cancel buttons simultaneously. * All LED's will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LED's. The control will repeatedly signal the code, as long as the Start and Pause/Cancel buttons are pressed. A two second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Aug 19, 2012 | Frigidaire AEQ7000EG Affinity Series...
Frigidaire affinity error code 12
Clear code, exit mode and start dryer. If problem persists, replace Main Control Board
Aug 17, 2012 | Frigidaire Affinity ATF7000E Front Load...
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Machine stuck on pause/err
May 28, 2008 | Frigidaire ATF6000ES Front Load Washer
May 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
80 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
