Are all of the sub-menus besides the clock unavailable or just the ones related to OTA (RF) signals? If it's just the OTA menus that are missing, change the source/input to TV. On all of my TVs, the channel scan option and related functions are blocked if the current input is not TV.
Changing the input/source depends on the TV. First make sure that an antenna or cable source on an RF (RG-59/RG-60 cable) is connected to the set. Next look for a Source or Input button on the original remote. Press this button. On some models, you navigate through the menu by pressing the Input/Source button repeatedly and then press OK to change the input. On other sets, you navigate with the arrow keys and then press OK. Some TVs may switch to the new source after a few seconds without any button presses; they don't need the OK button to be pressed. On a universal remote, you may find an Input/Source button but the button may not work with some codes for the manufacturer. (This can be frustrating since the basic functions (power, channel up/down, volume up/down) work; try a different code.)
Some TVs will also have an Input/Source button on the TV. This will work like the button on the remote. Use the Select button for the OK button. A few TVs have the option inside the on-screen menu. Press Menu and then look for a source option in a Tools or Setup menu.
I hope this helps. I have never had a TV where only the Clock menu is available. If that is the case with your TV, I don't know of a solution.
SOURCE: LG HGTV STB LST-3100A No scan no menu
Make sure you have an antenna hooked up to the antenna connector on the back.
SOURCE: I cannot change the time on the display clock
The clock is set by the cable co. There is no manual way to change it.
Electrode
SOURCE: Channel stuck on TV
This may work;
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
SOURCE: I set the INPUT to
your not saposed to use your tv remote to change chanels if you put it on input 2, im assuming you have a cable box, that is plugged into input 2, and if you are using the cable remote, after you put the tv on input 2, make sure you push the little cable buttom at the top of the remote befor you change the chanel
