Question about Health & Beauty
My motor master intelligent charger keeps flashing 8’s and I unplugged it overnight and it still flashes 8’s. Is battery charger done or is there something I can do to reset it?
Posted by Vince Pimpinella on
ray gallant
    Top Expert:
  • Health & Beauty Master
  • 67,013 Answers
Check with the manufacturer we have no clue here being diyer's mostly
Posted on Feb 23, 2020
5 Related Answers
Anonymous
  • 2985 Answers
SOURCE: when i try to charge my battery the red light keeps flashing
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
Posted on Jun 11, 2007
Anonymous
SOURCE: battery ran down.now radio/clock don't work. flashes Error.can this be reset?
try taking the radio out and looking on the top for the parts number. call Honda and tell them what is going on and they will give you a 4 digit code that will reset the radio. i had the same problem with my 05 civic, did that and it worked for me.
good luck
Posted on May 29, 2009
hawk127311
CURT
  • 350 Answers
SOURCE: dc1804f charger
If you have tried discharging the batteries prior to charging them already with no result and from what you describe in your post, then I would have to say the charger has issues. Go to HD or Lowes (not sure if Lowes carry Makita) but another charger and test your battery again. If you get the same fault, there is an issue other than the charger, if not you need a new charger anyway. If you get the same fault with the new charger, you can always return the new one. Short of opening up the charger and using a volt meter, this is the easiest way to test to pinpoint the real problem. I hope this helps and good luck!
Posted on Nov 06, 2009
Anonymous
SOURCE: p reset keeps flashing and won't print
Open the battery compartment and use a paperclip to push the printer reset button
Posted on Dec 07, 2009
jaipai2004
  • 3 Answers
SOURCE: have an eliminator intelligent battery
· Automatically switches from full charge to maintenance mode to maintain batteries during prolonged periods of storage without overcharging or damaging the battery
Posted on Dec 09, 2010
I have a motomaster nautilus intelligent battery charger, and no matter what I do I have 8's flashing across the screen. is there something that I can do get it working again?
Unplug, and leave it until the ;intelligent' part looses its power and all the voltage in it drains out and it will loose its memory.
After about an hour plug it back in an it will return to factory settings, If there is not an internal problem, it will work the way it did, (All voltages would drain out of most of them in 20 minutes, but a few would hold a charge overnight,) If there is an internal problem the display will go back to the flashing as soon as the 'intelligent memory' detects the problem. Is it possible that the detected problem is a bad battery?
Apr 03, 2018 | Cell Phones
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
24 v ryobi battery won't charge
Minimum FAST charge is 2 hours if it has a fast charge setting. If not, 6 to 8 hours to charge fully. I leave mine on overnight so about 10 hours..
May 22, 2016 | Ryobi Drills
Pioneer r-1 tablet won't turn on
Cant you just take it back to shop.
Mar 21, 2014 | Tablets & eReaders
The "in use" light keeps
Unplug the fax machine and take out the backup battery if there is one, let the machine sit overnight, this might reset the processor IC back into normal operation.
Dec 27, 2010 | Office Equipment & Supplies
I have the SSC-1500A battery charger and the yellow light keeps flashing. The yellow light is the charging light.not sure why
This unit will assume a battery voltage less than 1.5 volts means the battery is sulfated. The flashing yellow light means it has gone into 'desulfate' pulse mode using pulses of high voltage to try and convert the lead sulfate back into sulfuric acid and lead plating. It will do this for about 8 hours on the charger I have. If the voltage has not raised to a level that can can accept a normal charge it will abort the pulse mode and stop trying to charge it. You will need to unplug and replug in the charger to try again. Always check the temperature of the battery while charging it and especially if the charger is in pulse mode. Stop charging if the battery is hot. *always wear safety gear*
Sep 23, 2010 | Schumacher 400w Power Inverter
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
New battery in eMachine M6811 won't fully charge.
1) Control Panel / Security & Maintenance / Recovery
Feb 22, 2018 | E-Machines M6811 Notebook
My camera won't turn on. I've tried to charge the battery but th
I've had this happen to me in the past.  It generally means that your charger has died, or your battery's connections need to be cleaned.
Try using a Q-tip and some Windex to clean the contacts on the battery.  Let it charge overnight.
If that doesn't work, and you're still under warranty, contact Casio. They replaced a charger I had a few years back, no hassle.  They know it's an issue, and are pretty quick about replacing the defective one.
If you're not under warranty, a Casio battery charger can be found on eBay for a few dollars.
Mar 18, 2009 | Casio Cameras
Health & Beauty Logo
35 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
