Question about The Kitchen Appliances - Others
If I wanted to make a loaf with oatmeal, how would you Make it in the machine?
Posted by Renata Zanella on
Attique-ur-Rehman
    Top Expert:
  • The Master
  • 2,677 Answers
1. https://www.youtube.com/watch?v=pnj8MXlUWlk
2. https://www.youtube.com/watch?v=8LEZXXb8dmk
Posted on Feb 23, 2020
I forgot to enter the size of the loaf and I don't want it to bake for a 2lb loaf. I only added ingredients for a 1 lb loaf.
I would just check it around 40 minutes into the bake cycle. If it doesn't seem done let it bake another 5 minutes or so the shut the machine off.
Jan 23, 2015 | Toastmaster TBR15 Bread Maker
Recipe books
I have several recipe books for bread machines. You can use just about any book from other models as long as you follow recipes for your size machine. I.E. 1.0 pound loaves, 1.5 pound loaves, 2.0 loaves. Just be sure you choose the right loaf size when you program your machine and that your machine has the capacity to make the size loaf you want.
Jan 27, 2014 | Kenmore KTR2300 Bread Maker
Getting an HHH error message and cannot get to the menu function
That is a temperature warning that is an automatic feature on bread machines. What the machine is telling you is that the oven chamber is still too hot from baking the last loaf. It does that to prevent you from starting another loaf and having that loaf fail due to the high heat killing the yeast. If you want to bake more than one loaf push the STOP button till it beeps, unplug the machine, raise the lid, and leave it open for no less than 20 minutes. It should work fine by then if not let cool off another 10 minutes. It will be cool enough by ½ an hour to start another one.
Jul 26, 2011 | Cuisinart Kitchen Appliances - Others
Getting an error reading of HHH and cannot get to menu function. How do I solve this
Jul 26, 2011 | Panasonic SD-YD205 Bread Maker
Error code E:02 on Sunbeam Bakehouse BM3500S
May 24, 2011 | Sunbeam Kitchen Appliances - Others
Just baked a loaf of bread an now no power?
May 21, 2011 | Cuisinart CBK-200 Bread Maker
I just baked one loaf, and was readying the 2nd loaf, entered settings, hit start and got this: "E:01" What do I do?
That is a temperature warning that is an automatic feature on bread machines. What the machine is telling you is that the oven chamber is still too hot from baking the last loaf. It does that to prevent you from starting another loaf and having that loaf fail due to the high heat killing the yeast. If you want to bake more than one loaf unplug the machine after baking the first one, raise the lid, and leave it open for no less than 20 minutes. It should work fine by then. If not let it cool off another 10 minutes. It will be cool enough by ½ an hour to start another one.
Mar 26, 2011 | Breadman TR555 Deluxe Rapid Cool Touch...
I have a turbo baker II and I want to know if it is a 1.0 or a 1.5 lb bread machine?
Bread pan Capacities
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
Feb 05, 2011 | Kitchen Appliances - Others
I just ran this through the super rapid cycle as desicribed in the manual when first using the machine. Now I want to make a basic white loaf and the display reads "E01". What does this mean?
That just means that your machine was too hot to make a loaf of bread so soon after completing the rapid program. Bread machines need to cool off about 30 minutes before starting the 2nd loaf. They are designed that way to prevent poor baking results due to overheating of the yeast too early in the process. Please vote/rate/rank/testimonial this answer.......
Thanks!
Jan 08, 2011 | Breadman TR875 Bread Maker
Won't make oatmeal. Someone told me I could.
mistake can hapen you did not injured ourself mush that what important good luck pierre
Feb 12, 2008 | Mr. Coffee TFTX85 Coffee Maker
Kitchen Appliances - Others Logo
85 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
