SOURCE: night owl / night vision
Unscrew front lens front of intensifier tube should have an even bronze tinted coating on glass if it is grey and blotchy the tube is degassed. common fault with this model nightvision
wayne
SOURCE: battery replacement for Night Owl Night vision monocular
just press down and away from the lens, on the ribbed square located on the spine of the monocle
SOURCE: Dysfunctional Night Vision
dont power this up in full day light or you will burn out the ccd pick up if you cant see anything through it i gess the tude has burnt out
its common for this to happen there life span is only about 1000 hours and much less if exposed to bright light, ie minuets!
Testimonial: "Thank you. "
SOURCE: My Night Owl Cyclops NOCC3 night vision monocular
Hello, is the IR glowing red, don't look into the IR lens. Just place your hand in front of it and see the is a red glare on your had. If there is a red glare then IR is work.
Another thing when you taking a look see through the Night owl NV monocular there should be a green glow from the image intensifier tube, if not, then the NV monucular isn't working properly. stewbison
SOURCE: I put in a brand new battery in my night owl
Hello, this Night Owl monocular will have two light (LED's), one green for on/off, and other red LED for IR illuminator. So, does the green light come on? Also, if still does work, then send it to me. I some parts to fix other NV devise and 95% of them are manufactured in Russia including yours.
I wish you all the luck. GB...stewbison
