Question about Whirlpool Ovens
Model AKZM 656. What does error code F04 indicate?
Posted by Tomas Grondona on
1 Related Answer
tbirdfan1
Michael Thomas
  • 3056 Answers
SOURCE: fault f11 whirlpool akzm 656
Hello there and thank you for choosing fixya
the dreaded f-11 error code is a fault code that indicates that the touch pad is failing and needs to be replaced i would recommend that you first unplug the oven then disassemble the housing for the control pad and carefully inspect all of the wiring to see if any grease or dirt or things like this is in there and clean all of the parts really well then reassemble it and try it again and if the error is still there then yes the pad needs to be replaced ok?
Hope this is very helpful for you
Best regards mike
Posted on May 17, 2011
On my Fugor single electric convection oven: f03 error code. Error will not self correct after several times of turning off the power.
Web site quoted below:
Before calling for service, check the following to avoid unnecessary service charges.
Oven Problem
F03 or F04 Error appears in the display window.
A problem with latch mechanism occurred. Remove power and turn it back on again after a few seconds. The oven should run a latch auto-test. If condition persists, note the code number and call an authorized service.
http://www.google.com search result below:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwi0qdjJ18vaAhURuFMKHRjNBtYQFggvMAE&url=https%3A%2F%2Fwww.fagoramerica.com%2Fcontent%2Fdownload%2F4827%2F36165%2Ffile%2FFagor%25205HA_780X_Care%2520and%2520User%2520Manual%25200310.pdf&usg=AOvVaw1ewC8YnHKLRvnE5MVd2a1d
https://www.fagoramerica.com/content/download/4827/36165/file/Fagor%205HA_780X_Care%20and%20User%20Manual%200310.pdf
Apr 21, 2018 | Ovens
A F04 Err is flashing on my Bosch double oven. Please can you tell me what this means?
The only F04 error on a Bosch oven is with the Bosch 5000 Series wall oven. On this model, the problem is with the door latch. Unplug (or turn off at the circuit breaker) the oven. Turn it back on after a few seconds. When the power comes on, the oven should do a self-test of the lock mechanism. If the error persists, you'll need to do some diagnostics to determine if the lock is faulty. The problem could also be with the wiring or the control board didn't register the correct signal from the lock sensor.
Please add a comment with the model number of the wall oven for more assistance and any possible parts lists. You may want to call for service if you aren't comfortable doing this work. You probably need to get the oven out of the wall cavity for some of the diagnostics.
I hope this helps.
Feb 24, 2017 | Bosch Ovens
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
Frigidaire model FEF352CATB has a F3 error code
Hi - Typically error code F3 indicates a faulty sensor probe or wiring harness between sensor probe and EOC. Try resetting the range by unplugging it or flipping the circuit breaker off for two minutes (this usually will clear most false error codes). Turn on the range and if resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 14, 2012 | Frigidaire Ovens
Fault f11 whirlpool akzm 656
Best regards mike
May 17, 2011 | Ovens
What does cde f5 indicate
Hi, this is just a sample of some error codes, you do need the brand and model number for you to get a good idea on what the failure code is for your oven. link to follow: http://www.managemylife.com/mmh/questions/110137-does-f1-f2-f5-error-codes-indicate-oven
Dec 11, 2010 | Ovens
How do i fix error code F04 on Zanussi ZPB1260 single oven
Error Code F04 is due to the mismatch between the incoming line voltage and the voltage setting of the oven. To correct the error code follow the instructions given below : a) Make sure the line voltage corresponds with the setting of the oven. The voltage selector is located at the back and consists of two plugs. The white plug sets the oven for 208 V and black plug (or white plug with a black dot) sets the oven for 230 V. b) Make sure the line voltage is within +/- 10% tolerance. This is especially important during summer months, where line voltage has tendency to drop. c) If both steps above check OK, the error(s) may be caused by defective controller (DPU) board.
Jan 20, 2010 | Ovens
GE Electric Range Model #JBP95A F1 and F7 Error Code
F1 is a common error code indicating a failure of the oven control board (aka ERC or EOC). Often these control boards have been discontinued, "no longer available" or are very expensive. We may be able to help and save you money.
We refurbish oven control boards at www.fixyourboard.com.
Mar 29, 2009 | GE JTP27 Electric Double Oven
I have an F7 error code
This usually indicates a stuck key, requiring keypad replacement.
This often involves replacing whole console assembly. You need full model a and serial to order parts.
Nov 22, 2007 | GE JGRP17 Gas Single Oven
Ovens Logo
100 people viewed this question
Top Whirlpool Ovens Experts
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
