My stereo amplifier ( ax-570 ) it is not work
Posted by Jason. Barekiau on
GARY BAKER
Most of the time, they have fues in the curcit boarbs. means going inside, but the fues cost next to nothing. is up to you I would look myself, but its your call. make sure you unplug it first.
Posted on Apr 02, 2020
3 Related Answers
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: matching book shelf speakers for yamaha ax 596 amplifier
just click to choose;
NEW iBALL BOOSTER 5.1 SPEAKERS WITH MANUFACTURER WARRANTY
The iBall Booster is a high quality 5.1 speaker system with complete wood encased speakers. Gives... control...
FREE 350 WATT AMPLIFIED SPEAKERS Creative Inspire 5200 5.1 Multimedia Subwoofer Speaker System With 1 Year Warranty
hope this may help;
Regards,
VOTIT
Posted on Jul 29, 2008
Anonymous
  • 10594 Answers
SOURCE: need a new transformer for
let me give you a tip ;) power transformer has thermal fuse inside its tape-bounding area. try to locate it and check..transformer might be Ok and fuse has blown.
Posted on Aug 13, 2008
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I have a JVC ax-r87bk
Posibly nothing. Look at the controls and indicators for a clue.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause forintermittent shutdown.
Posted on Jul 11, 2011
Yamaha AX-596 bass & treble control panell not working
Make sure there is no tone bypass button if it has one.
Need connecting wiring for sony am/fm jx 285 connecting to the sony stereo amp ta-ax 285
If you are trying to connect a ribbon cable tuner to a conventional RCA input terminal amplifier, it won't work because the ribbon cable carries the signal output as well as the data for frequency synthesis which is determined by the processor located in the amplifier ( that is supposed to work with that type of tuner), and the data buss for the buttons on the front of the tuner.
For the time and effort to put into a workaround, it is cheaper by far to get a tuner that will work with your amp. If cosmetics are not an issue, brand of tuner will not matter as their outputs are "Line Level" or nominally 1 volt peak to peak..
I have a Sony Bravia KDL-46X3100 tv set which I want to connect to my Yamaha RX-V730 amplifier so that we can listen to tv programmes through the sound system. How do I connect them using RCA cables as I...
all you need is one set of the red and white rca cables.your tv should have an audio output with a red and white hole.plug in red and white wires to those holes at the back or side of your tv.plug the other end to your auxilary red and white holes at the back of the stereo....if your stereo doesnt have aux holes then you can plug into L.d.,VIDEO outputs at back of stereo.you then turn your select button,nob on your stereo to either the aux,ld or video.hope this helps
Hello i was wanting to know if i could hook up my AX-596 amplifier to my Yamaha HTR-5860 reciver
I assume you want to slave it to the receiver and drive some more speakers with it.
Connect some RCA cables from whichever channel pre-outs you want on the HTR-5860 to any input on the AX-596.
Set the AX volume to something sufficiently high, run through the HTR's speaker level setup and match the AX volume to match the channels on the receiver. Then leave the AX's volume alone.
If you just want the AX to have access to program sources of the HTR, run the RCA cables to it from one of the VCR1 or 2 Out (but DO NOT select whichever one you use via the front panel). These are not affected by the HTR's volume controls.
3helpful
JVC AX-66 Integrated Amplifier seems to be muted?
You need to have a jumper between the 4 standalone jacks on the right side of the column of stereo connectors. A stereo RCA cable would work for this.
Convert passive speaker to active
You don't say anything about your passive speaker, only thing that I understand you have a Yamaha AX-396 witch have an Power output of 60 watts per channel into 8 ohms (stereo)! That means working great with your passive speaker!!!
Yamaha AX-930 Audio Amplifier
HI...
Do a websearch for a competent repair shop in your region or ask the stereo folks where you got the amp.
It WILL need surgery.
Cheers,
Scott
Matching book shelf speakers for yamaha ax 596 amplifier
hope this may help;
Regards,
VOTIT
 Grubhead
Grubhead
