Question about Casio Office Equipment & Supplies
How can i replacement the Gears printer for casio c450
Posted by Ehab on
Leroy Elliott
    Fixya-Fanatic:
    Visited the website for 90 consecutive days.
  • Casio Master
  • 425 Answers
No spare parts
Posted on Feb 22, 2020
Testimonial: "How can i replacement the Gears printer for casio c450"
KONICA MINOLTA C450 DEVELOPER
Sir/Mam you do not need developer for the C450 it already comes inside the image unit the copier tells you to replace.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 05, 2014 | Konica Minolta bizhub C450P Laser Printer
ERROR CODE LIST FOR KONICA C450
C450 P or c450
Nov 26, 2013 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta Bizhub C450 touchscreen doesn't work
You need a new touch screen panel or I/O cable, they are fairly expensive if you don't have a service contract with your Office Printer supplier. Recently just replaced one a few months ago.
Nov 28, 2012 | Konica Minolta bizhub C450 Touch Panel...
Bizhup c450 code c2555
i have error c450 in konica menolta c450
Oct 29, 2011 | Office Equipment & Supplies
Casio cash register feeding belt for til roll broken
I think you are referring to the takeup belt that turns the black takeup spool. In which case you would most likely have the M820 or M825 printer from the TK series cash register (was I close?) If this is the one you are trying to fix, it is tricky because you have to remove the side plate where the gears are housed. If you spill the gears out of the plate, you will have work out how to re-mesh them. It is best to have this repair performed by a Casio technician. --------------------------------------------------------------------------------------
For those of you looking for a Casio TK-1300, TK-2300, or TK-2700 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Jun 16, 2010 | Casio Parts Cash Register PC Desktop
Sony DAV-C450 disc jammed. How can I remove them
your two options would be to remove the cover and disk tray and than remove the disk while nothing is in your way your other option would be to pry it open using a flathead screwdriver which could damage the tray motor and gears neither is suggested if the item is still under warranty or you lack general assembly skills
Mar 30, 2010 | Sony DAV-C450 System
My printer died on my ce 4000. can I buy a replacement printer
The cost of the printer will be as much as a new machine. They are very expensive. It is better to fix the old one. As long as you ran paper in both sides of the printer, it will probably be worth fixing. Mostly the gears and motor fail in this version and they are cheaper than another printer. Hope this helps.
-------------------------------------------------------------------------- If anyone else is looking for a Casio CE-4000 manual, http://the-checkout-tech.com has one here:
http://the-checkout-tech.com/manuals2/cashregisters/casio1.php
Feb 10, 2010 | Casio Parts Cash Register PC Desktop
Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Mar 02, 2009 | Konica Minolta bizhub C450P Laser Printer
60 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Carlo Barzo
Carlo Barzo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
