Cameras Logo
Question about Green Cameras
It won't complete a charge, when I think it's charged I unplug and plug back into make there is a green light but it's still red and won't complete a charge
Posted by Patty Nowiszewski on
Tony Parsons
  • Green Master
  • 6,402 Answers
To what make and model of camera does this statement refer ?
Posted on Feb 21, 2020
How do you know when the battery is done charging
  1. Plug the charger into the mains, the light should come on GREEN.
  2. Now clip your battery in, the light should go to RED, indicating that the battery connected and is charging.
  3. Once the battery is fully charged, the light will go back to GREEN, indicating that the charge procedure has completed.
    Hope tis helps :)
Apr 08, 2016 • Worx Garden
1helpful
Brand new out of the box Volitation 9053 wont take a charge. Charger never goes green to indicate full charge. At most I get 5-10 seconds of weak spin and then the red light on the ECS board flashes. ...
  • If this is a brand new item out of the box, if this were my item, I would send it back for an exchange. The charger never turns green because the battery never gets a full charge. Because of that you won't get a 7.4volt reading out of the battery, Either the battery is not taking the charge or the charger is malfunctioning and not charging proper. The lights may work for a bit while the motor won't spin because a light takes far less voltage than turning a motor. Because you don't know if it is the battery or charger and it is new I have to suggest to take it back. The sooner the better. Messing with it will just void the warranty.
Regards, Tony
4helpful
2answers
Lost Dynamic Falcon Mini Copter Manual/Instruction. What Does Flashing means while charging and why the green light isn't on?
The flashing red light means the batteries are low. The green light goes off when it's finished charging, or when there's not enough battery left to charge it.
3helpful
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
4helpful
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
26helpful
2answers
Battery won't charge on my ryobi 14.4v cordless drill yellow and green lights stay on
I had the same problem and found a solution on another forum...
Plug the battery into the charger. The yellow and green lights come on. Leave the battery plugged into the charger. Plug and unplug the charger power cord from it's power source a few times until the the red charger light comes on..... problem solved!
I think the "smart" circuit in the charger that is supposed to trickle charge before the regular charge cycle needs at least some battery power to test and start the cycle. If the battery is totally discharged, the test can't deternine the battery status and will not charge.... Plugging and unplugging the charger seems to bypass this teat and charge the battery normally. The charging process should work normally after this method.
Oct 22, 2009 • Drills
Kenko
read the owners hand book
normally the lights stay red until the battery is charged then it goes green
if the power is cut or if you switch the point off with the charger still in it and do not remove the charged battery , the battery will discharge through the charger
Powering on
OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
Hope this works for some others.
3answers
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Top Green Cameras Experts
NOEL
NOEL
Ngoro
Are you a Green Camera Expert? Answer questions, earn points and help others
