Screen shows 4 squares of the pictures. My remote control shows RM-SXV053J. What should I do?
Posted by Solange on
David Spradling
    Top Expert:
  • Televison & ... Master
  • 10,974 Answers
Go into picture set up and turn off multi pictures
Posted on Feb 25, 2020
4 Related Answers
Anonymous
  • 10 Answers
SOURCE: How do i get my tv to show the picture straight
THE IS A BOTTON FOR THE ALIGNMENT UNDER THE POWER BUTTON. CLICK ON IT AND SEE IF IT CLEARS. IF THAT DON'T WORK LOG ON TO THE WEBSITE BELOW AND READ ABOUT THE COLOR ADJUSTMENT FOR THE SCREEN VOLTAGES. IF THAT DOESN'T CALL A PREFERRED SONY REPAIR SHOP FOR ADVICE.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Dec 15, 2007
Anonymous
  • 405 Answers
SOURCE: Black square in picture .....
Try picture in picture button on remote?
Posted on Dec 27, 2008
Ecollier2012
Edward
  • 3459 Answers
SOURCE: I have a double picture on screen i could hear my TV but the color are off too with Sony RM-Y908 Remote Control? which is broke
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Feb 05, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: HI, MY TV PCL5415R, HAVE SOUND BUT NO PICTURES SHOW ONLY BIG BLACK SQUARE
Set would seem to be either in PIP (picture in picture multiple mode) or the black box might be the TEXT feature which is found in the closed caption menu.
Posted on Nov 04, 2012
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Split screen button not working
Split screen means 2 pictures side by side--one is ok or both are bad?
Apr 03, 2012 | Sony RM-Y916 Remote Control
Picture has lines and goes black after warm up
Try unplugging for 2 mins. Or press power button for 30 seconds. Your Light in the tv might be shot.... happens every 5 or so years.
GOOD LUCK
CNBY
Jun 03, 2010 | JVC RM-C18G-1H Remote Control
My tv is stuck in picture and picture mode with a split screen
this a prb with u r picture tube...u jus call u r service provider...they will take care of u r tv...
Jul 25, 2009 | Sony RM-Y135 Remote Control
TV has a black square box blocking out the channel
this is probably the closed captioning option, go into the menu and turn off closed captioning, its probably on text....Hopefully this helps
Jul 18, 2009 | JVC RM-C745 Remote Control
Dec 27, 2008 | RCA Universal Remote Control
I need a manuel for the Sony Remote RM-Y916
just go here and choose the type of device and brand to get the code
then the instruction are towards the bottom of the page
electech
Nov 27, 2008 | Sony RM-Y916 Remote Control
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
