Question about Toshiba Televison & Video
I have a Toshiba 55 inch LCD tv 55l621U with blue screen. I just replaced the t-con board. still have the same issue. Power board seen to be ok I got all the volts going to the main logic board
Posted by jose aracena on
shibu tv
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
Connect universal board to confirm panel or main board
Posted on Dec 06, 2020
5 Related Answers
Anonymous
  • 120 Answers
SOURCE: Westinghouse lvm-47w1 picture goes dim
Hello, I can tell you from experience that this is an inverter issue. Both the master and the slave have several transformers and sometimes you can't tell if they are damaged or not. I would recommend testing the leads from the inverters to make sure which one of the two is the one causing the dim picture.
Posted on Apr 15, 2010
Anonymous
SOURCE: I have a Samsung LNT4665FX with screen problems. I
To solve this type of problem, you need a piece of white chalk. Draw a line around the area where the set is at. Call a priest - and lay the poor thing to rest!!!! This isn't the first time Samsung has "dropped" junk onto its' customers. Their dvd players also had problems with their DSP I.C.s that would over heat and cause the video playbacks to "break up". Don't waste any more time or money on the product!!!!!
Posted on May 18, 2010
Anonymous
  • 160 Answers
SOURCE: MAG 3200 Lcd TV I
Hello.
Normally T-Con board have nothing to do with powering up of TV. It's only affecting image when TV is on. So we can discard T-Con as a suspect for now.
Remove "new" main board and install the old one. If TV powering up and back light comes on - you've purchased defective Main Board and you should return it for exchange or refund. It happens all the time, boards that they sell most of the time are refurbished and sometime nothing was done and they send defective board to the other customer by error.
In case that TV is not powering up even with the old main board - look for something that you have done during replacement (like forgotten or overlooked connection, broken/bended pins etc.).
Russ.
Posted on Aug 28, 2010
Anonymous
  • 10594 Answers
SOURCE: I have a Samsung Ln32A450c1d
Basically it is problem of LCD Panel (screen) however some times T-Con board replacement fixed the issue (T-Con board is part of lcd panel but some part shop sell it separately). Main board is not related with this kind of problem.
Required T-Con board is available in ShopJimmy.com (click the link to view available boards)
If T-Con board replacement does not solve half screen vertical lines problem then LCD Panel will be replaced and it would cost approx new tv price.
Hope this info will help.
Thanks.
Posted on Mar 28, 2011
chapelure09
Anoni Muss
SOURCE: Hannspree 28 Inch Lcd Tv Model Number HSG1075
Stop buying hot TVs folks. If you bought it legit, you can take it back.
Posted on Oct 23, 2013
2answers
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
1helpful
Why is the t-con board in my Toshiba Reza 42HL67 LCD TV repeatedly dying?
Could be just bad luck! It seems unlikely to me that the power supply would take nearly a year to destroy the T-con board!
You could get in touch with Toshiba to see if there is some kind of problem that is cropping up on this model that might cause failure in on the T-con.
1helpful
2answers
Lcd tv screen replacement
The value of screen is most of your tv,if you replace screen,you will take about two thirds price of your tv,we suggestion,you can buy another TV.
From Wisiny.com can find those parts,power supply,inverter boards and t-con
Phillips flat screen has a vertical blue line, about 2inches wide, running from from the top to about a third down the 52 inch screen. What causes this
Take ur hand and pushes all around the tv frame bazel see if the veritical blue line react like flashes or lighter or darker,than this tv can not be repair at all because the LCD screen itself it is the caused,the LCD screen cost same as a new tv if it is require to be replace.If there are no reaction of the blue line at all than ur tv have a circuit board problem.The T-CON board is dying,this board sit in the middle bottom of the LCD screen,must be replaced will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-Con board for the replacement.
Samsung LN46B650T1FXZA has vertical lines. What part needs to be replaces? Thanks, Nina
This might be a bad T-Con Board. This is the board that is in the middle top side of your TV. It connects to your main board (with the hdmi inputs) to the LCD Screen. Your TV has a major issue with the T-Con Board going back. The T-Con for that TV is avaialble here 55 46T03 C11 Samsung Con Board for LN46B650T1FXZA
1helpful
2answers
We have a 52" Toshiba
This problems is not the causes by a human or an objects by hitting the LCD screen panel wright?If,yes this problems can't be repair,the LCD screen panel it dead.The tv now,only can be used as spare parts,not worth as a whole tv anymore.If tv it develope all these colors lines by it self?Yes,this tv can be repair,the board call the T-Con decoders board is the causes and the problems.This T-Con decoders board sit right at the middle botton of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
I have a 32 inch MAGNAVOX LCD TV that exactly half of the screen has a gray or white film in front of the picture but the picture can still be seen behind it. The other side of the tv screen is perfectly...
This problem is the cause of the T-CON board is dying.This T-CON board sit at bottom of the LCD screen right in the middle of LCD screen.Change this T-CON should solved ur problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
No backlights
The T-Con board is dead.This board sit right in the middle in the bottom of the LCD screen panel.This board is dead,require replacement.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con board for the replacement.
Blue screen, no picture, audio works fine. TV
I have the same issue. I am thinking I need to replace the T-con board. Did you get your fixed and what did you need or do?
Televison & Video Logo
Top Toshiba Televison & Video Experts
 Grubhead
Grubhead
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
