Question about Vizio Televison & Video
Trying to figure out what's wrong with my vizio smart tv. I've changed the t-con board, but ig still has the lines that change width and color occasionally.
Posted by Christy R on
Muhammad Junad
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
It seem to me that your tv have issue in the screen not in the board.
Posted on Feb 25, 2020
5 Related Answers
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: My Samsung hdtv model LN46B650
You should download the PDF and learn what the T-CON/LCD panel failure can do to what you see on the screen.
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
http://www.mediafire.com/?zzjygannjty PDF download.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on May 20, 2011
eagle338
eagle338
  • 4889 Answers
SOURCE: i have a vizio 42" lcd tv and it is a 2007 model.
T-con and inverter boards are not related to this problem so you might as well return them for a refund. When you try to power it on what is the status of the LED at the front ? Does it remain in standby mode or does it turn on but does not respond to any command?
eagle338
eagle338
  • 4889 Answers
SOURCE: Samsung LN52A550 - 2 1/2 years old - I have
It could either be the T-con(AKA LCD controller) or its the LCD panel. It cannot be anything else. So you should give the T-con a try and chances are it can fix the set.
Posted on Jun 28, 2011
Jason Morris
  • 362 Answers
SOURCE: My Vizio 55XVT1A power on, has sound, but no picture. I changed new power board, main board, T-cond board, but it still same problem. What's wrong with it? Is it anything with inverter board? Than
If this is an LCD tv the backlight inverter is bad, a good way to check it is to shine a flashlight close to the screen and see if you can see a faint picture.
Let me know what you find
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Feb 19, 2012
gopakumarg43
  • 76633 Answers
SOURCE: color lines on 42inch vizio
Hello
The y SUSTAIN board to your tV is faulty. It should be repalced.
Posted on Mar 01, 2012
Vizio 60" smart tv screen bottom section of the screen is lighter than the top
Sounds like you have some bad lamps in the panel that need changing, in time the backlights will totally go out and the set will have a black screen
3helpful
2answers
Vizio Vo37L fhdtv10a has no audio or video. Vizio emblem changes color with panel or remote power button. otherwise no response. Don't know whether to suspect panel, T-CON, or main board. Thanks
Chances are you can rule out the tcon if you don't have sound, it could be either the main or power board, if you have a meter you can test the voltages on the power supply and see what is missing and figure out if your getting the signal from the main to turn enable PFC
Help fixing a Vizio M651d-A2R
Try a new tcon board and see if that helps.
M470NV troubleshooting screen, i am trying to figure out if it is the t-con board or LED panel.
T'Con board fault. With most modern LCD TVs; this board is an integral part of the display panel, and cannot be replaced.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Should I change the T-Con Board?
t-con is my first choice, but failing that, the screen is dead, and the tv needs replacing.
I have a Vizio E320I-A0 and it has multiple vertical and horizontal lines on the screen, how do i fix that?
Probably the T con board is faulty. T con board is the one which drives the lcd pixels. Chekc the video to identify the t con board. Also try to remove the connection to T con board and reconnect it. some times bad contact on those connectors can lead to such problems.
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
www.electro-medical.blogspot.com
1helpful
2answers
I have a 55 Vizio 3D smart tv. This picture color fade in and out to the point that I cannot watch tv. I this a problem with the main board?
Hello Patricia,
  • There is a loose soldering connection in the Main Board. That happens because the components on the are generating a lot of heat therefore melting solder connections.
  • Stop beating on the TV's back, that only makes the problem worse.
  • Take it to a shop.Or if you are a tech, try locating the loose connection(s) and solder it back.
  • Also check your Warranty Period, It may cost you 0$. Call Vizio if you still have Warranty on the TV.
Here is a link to Vzio Supoport.
Good Luck,
JP
VIZIO Product Support and Services VIZIO
Need help please. Why has my Vizio TV malfunctioned? And what are my options?
It sounds that the T'Con board [Timing Control Board] to your TV is faulty. But before confirming it, just re-seat all the flat cable connections from it to LCD panel. You must have knowledge in electronics to proceed. Otherwise, seek help of any experienced service technician.
Televison & Video Logo
Top Vizio Televison & Video Experts
Paul Bade
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
