Question about Roku Televison & Video
I have a TCL Roku T.V. 55 inch . When I go to turn it on it has a light blue screen, when i disconnect the power wait a few seconds and plug it back in the TV reboots itself then goes to menu just like it should. Some times it will show the blue screen and sometimes it works just fine. What's going on with it, should i buy a TV repair kit maybe TCon board, power board or main board
Posted by Gary York on
David Spradling
    Top Expert:
  • Roku Master
  • 10,974 Answers
Weak capacitors on power board
Posted on Feb 25, 2020
5 Related Answers
premtech
William Rayburn
  • 934 Answers
SOURCE: Insignia IS-LCDTV26
Just posted the answer to this to SDBudman look it up... It's a fairly easy and common problem.
Good Luck!
Bill
Posted on Apr 08, 2008
Anonymous
SOURCE: Magnavox MS3252S431
Replace:
Q7461 C33725
O7463 C32725
C2455 [email protected]
Posted on Jun 17, 2008
Anonymous
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
Anonymous
  • 5 Answers
SOURCE: tv keeps disconnecting from digital tv, returns within 5 seconds but highly annoying! pictue goes blank and sounds goes aswell , almost like the tv has turned off only to restart itself
It sounds like it is loseing signal, check your connections, and make sure you have the correct cable
Posted on Jun 01, 2009
Cary Leonardt
  • 304 Answers
SOURCE: Hello, I have a Samsung LN-S4692D.
You cannot test the T-Con bd with a meter. However if you have the luxury of having another same model tv, you can install the bought T-Con bd and see if it is good or bad. Since you said the Menu and channel flashses, then I would replace the Main board.
Posted on Apr 16, 2010
I have a TCL Roku TV model 32S3750-W. My Netflix stop working. After selecting Netflix all I got is the Netflix logo
Hello
Just Follow these steps:
    1.Turn off or unplug your streaming media player.
    2.Unplug your modem (and your wireless router, if it's a separate device) from power for 30 seconds.
    3.Plug in your modem and wait until no new indicator lights are blinking on.
    4.Turn your streaming media player back on and try Netflix again.
    For any help or support just visit us: www Netflix Com Activate
Nov 16, 2017 | Roku Televison & Video
Roku remote does not operate. Also have to reboot Roku often
Hello
Roku remote will not pair
    1.Restart your Roku device and remote.
    2.Then remove the power cable from the Roku device, wait five seconds, and plug it back in. When the Roku home screen appears on your TV, put the batteries back into the remote, wait 30 seconds for the connection to be established, and press a button to see if it works
    For any help or support just visit us: www Roku Com Link
Oct 09, 2017 | Roku Televison & Video
Ho do I add my Prime to a TCL TV with Roku?
  • Turn on the TV by switch on the 'Power' button.
  • The user can see the status light blinking after few seconds.
  • The screen with TCL Roku TV logo appears once the process for appliances starts up.
  • From your remote press the 'Ok' button on the right corner.
  • The onscreen instructions visualised has to be followed by the users to complete the process of setting up the TCL Roku TV.
  • The users can opt the 'Home' mode option and even to connect with external devices using a valid internet connection.
·For more query resolving please get in touch with our 24x7 customer support at +1-888-269-1011 to get further help.
Aug 02, 2017 | Televison & Video
Roku 1 not working with remote
Check the condition of the battery in the remote. If no good, replace.
Reboot the Roku by disconnecting from power supply, wait a few seconds and re plug unit. Should work then since I have had my Roku lock up like this on 2 occasions.
If neither solution does the trick you just hope unit is still under warranty.
Mar 12, 2015 | Bose® CORPORATION Bose - RC-PWS II...
It's connected to my wi fi but it's telling me it can't connect to roku it says error code 011
The E011 error code is usually a router firewall problem. If you can turn off the firewall in the router when installing Roku that may solve the issue. This is not to be confused with the computer firewall in Windows which is left ON. When you go into SETTINGS/NETWORK your screen should look similiar to the attached picture. 25351243-jkwiv2v3rghcuytcwoewo3pc-1-1.jpg
Jan 02, 2015 | Roku Streaming Stick
My 39 inch tcl led TV power cord got abrubtly unplugged while watching TV. Plugged it back in and now the TCL logo on the start up screen stays there frozen. Many times already tried to unplug it, wai
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again.
Sep 14, 2014 | TCL LE39FHDF3300 39" LED TV 1920x1080, 60...
TCL Blue Screen "No Media"
I HAVE FOUND THE ANSWER!!!! I just bought an TCL TV last night and was given the wrong remote. Screen was stuck on "no media" screen BUT I noticed that when I turn the tv on and keep pressing the menu button, the menu screen would pop up for a half second before the no media screen popped up again. So I knew it was able to access it. SO, it took a few try's and with no exact method I turned the tv on, waited til I saw the TCL logo and then simultaneously pressed the menu and channel up button repeatedly. It will open the menu for you and allow you to move between the input channels!!!! It WILL take a few tries to catch it but it worked!!! Your welcome!!!!
Dec 29, 2012 | Televison & Video
Streaming media player wont turn on or has no power?
Hello Friend
Remote and Roku Need to Be Reset. Remove batteries from the remote. Hold down every single button on the remote for five seconds. Next, unplug the power cord from the Roku, wait for five seconds, plug the power cord back into the Roku, and wait for Roku banner.
For any help or support just visit us: Roku Com Link
Aug 09, 2012 | Roku HD Streaming Player
TLX-04011c no screen but has power red light turns to blue light
Disconnect from power. Wait 30 seconds. Plug back in. Use the power button on the TV for first turn on.
Jun 25, 2011 | Polaroid Televison & Video
Televison & Video Logo
Top Roku Televison & Video Experts
Thomas Stauber
Thomas Stauber
Brandon Black
Level 1 Expert
ZOX INTERNATIONAL
ZOX INTERNATIONAL
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
