Https://printcopy.info/?l=ru&mod=erc&brand=Toshiba&model=e-Studio%202505H&code=C449
Service manual online at link above
Quoting from link above: "
SOURCE: My Toshiba E-studio28 Copier stopped working
its sounds like the developer is dry (out of toner) try opening and closing the front cover multiple times (no less than 5x) if it is still on you will have to call toshiba service provider to correct issue
SOURCE: I have face my Toshiba estudio copier machine
this error is for the data base not working check the harddrive is not faulty if you can hear a stuttering at initialization it could be a faulty HDD
SOURCE: My E-Studio Toshiba- 720 giving
The error code C449 relates to your fuser, and it signifies that it is overheating. To identify the exact issue you would have to check all of the thermistors for the fuser assembly, the heater itself, as well as the LGC board. Please note that unless you have the training, experience, and proper tools I would not advise trying these procedures. As you are dealing with the fuser you can injure yourself or damage the unit if the proper safety precautions are not followed. Contact your local Toshiba repair center and arrange for a repair tech to do them. These are the detailed steps to follow:
1) Check to ensure that your power voltage is normal. During operation of the unit your voltage should not be more than +/- 10% of normal.
2) Check the thermistors to ensure all connections are good, that the front and rear thermistors are in contact with the fuser roller so that they are able to detect correct temperatures. Also check to ensure the there connections are still holding correctly.
3) Check the heater itself to ensure that the coil is not broken, that the connections on the coil are still intact, and that the thermostat is not blown.
4) Ensure that all heater connections to the control board, especially the AC input connector and the LGC I/F connectors CN455 , are still good.
5) Check to ensure that the IH control board has no abnormalities such as burnt or melted components.
6) Check the LGC board to ensure all connectors, especially CN332 and CN334, are still connected. Also check to ensure the conductor pattern is not short or open circuited. If necessary replace the LGC board.
Beyond those steps you would have to clear the status counter. To do so you would have to follow the procedures outlined in the service manual. You can either purchase the manual online if you are capable of repairing the unit yourself, or have your local Toshiba repair shop send out a tech.
SOURCE: i have One Copier (Toshiba
Charger cleaner motor abnormality: Charger
cleaner motor is not rotating or wire cleaner is not
moving normally.
SOURCE: sir i have Toshiba 207 copier sir now write on
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine. When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
Thanks
Best Regards
