Question about Ricoh Office Equipment & Supplies
How to remove sc302 error code for my ricoh aficio MP 201 SPF?
Posted by Jean Dider Deslorges on
5 Related Answers
Anonymous
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
Anonymous
  • 95 Answers
SOURCE: Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Posted on Mar 27, 2009
Anonymous
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Posted on Apr 11, 2009
Ickoajnc
OfficeServiceAjnc
  • 211 Answers
SOURCE: Ricoh Aficio MP 1600 Le error code sc 322 occured
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
Posted on Jan 13, 2010
Anonymous
  • 114 Answers
SOURCE: scanrouter v2 lite at ricoh aficio MP 4000
you dont need scanrouter for mp 4000
Posted on Mar 21, 2010
Ricoh aficio MP2000 ERROR code SC302.
https://printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20200&code=SC302
Ricoh Aficio 200 Error Codes
Ricoh Aficio 200 Error Codes Code:
Code
SC302
Description
Charge roller current leak
A charge roller current leak signal is detected.
Causes
• Charge roller damaged • Charge high voltage supply board defective • Poor connection of the PCU
Apr 18, 2018 | Ricoh Computers & Internet
Ricoh MP201 SC820 CODE 612 Detail 40000000
[06FF]: Detailed error code
The pipeline clock frequency
rate is different from the
prescribed value.
?? Defective CPU devices
?? Mode bit data error, which is used
for initializing CPU.
1. Replace the controller board.
Apr 09, 2017 | Ricoh Aficio MP-201 Copier w/ Duplex...
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP1600
I do find the error code for a different Ricoh model (Aficio 1018).
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%201018
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
RICOH MP 2000 ERROR OCCURED SC302
That is a charge roller current leak. A current leak signal for
the charge roller is detected. Possible cause- charge roller damaged or high voltage supply board defective. Check the charge roller first. On the drum, the rubbery roller.
Jul 10, 2014 | Ricoh Aficio MP 1600L Black and White...
How can i solve error code sc:302 in ricoh Aficio 2000 copier.
Is there any immediate solution for the ERROR SC302 for aficio 1018?
tnx
Aug 24, 2010 | Ricoh Aficio MP 2000 Black and White...
What error code 302 ricoh aficion 2016
Hi Manas,
Error code - SC302 is caused due to the leakage in charge roller.
In order to rectify the issue you need to replace the drum and the charge roller .
Nitin
Sep 11, 2007 | Ricoh Aficio 2016 All-In-One Laser Printer
Open Questions:
93 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
