SOURCE: The lens keep going in and out
mine camera did the same thing. i gave it to my techno neighbor guy and hours later he gave me my camera back and it was FULLY functional! he "hit it several times" thus jarring the lens back into place! (i could have gone w/o hearing that but, hey! it works!
SOURCE: Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
SOURCE: Access Message
Could not believe it but it worked for me as well. First time I see that a good smack makes it work
SOURCE: Sony Cyber-Shot DSC-W30. The lens is in a "stuck" position
You have a bad lens, it prob. also says turn off and on again.
SOURCE: SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
apparently i have some bad news , its the lense which is misaligned or broken in terms of gears, the thing to do turn on the camera and make sure that lens is out and then LIGHTLY tapp on the lens the direction of which you feel that the lens is not equal legnth to the outer ring > place that looks uneven
