Question about Kenwood Audio Players & Recorders
Kenwood VR309 ..I power on all speakers disconnected and within few seconds shuts off ..tried a different plug in and got same results the fuse in reciever looks to be fine any suggestions
Posted by Eric Oconnor on
john h
    Top Expert:
  • Kenwood Master
  • 24,045 Answers
Check and test the circuit for damage short or overheating
Posted on Apr 07, 2020
5 Related Answers
Anonymous
  • 6966 Answers
SOURCE: I have a Kenwood KR-V7030
Since it was just recently installed, would it be safe to assume that it is fairly new? If yes, perhaps your best bet would be to return to dealer/manufacturer for repairs/replacement. It is highly probable that the unit has sustained major hardware fault at least on the right channel. Even if it were just a fuse, it would still be to your advantage going that route.
Should for some reason you would venture a DIY, diagnosis and repairs of course would require fair familiarity with electronic components and circuitry, use of a VM and a soldering iron and preferable access to a service manual or at the very least a schematic diagram with voltage readings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 29, 2008
Anonymous
SOURCE: Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Posted on Jan 28, 2009
neOen
  • 36 Answers
SOURCE: TV powers up initially, but shuts down within seconds.
These TV's are somewhat sensitive to internal heat. It appears your sensor has triggered an overheat. This doesnt mean you still have the heat issue, it just saying it needs to be replaced or reset, either way it is not something you can do in your home. Taking it to your local authorized shop will ensure proper repairs, about $90 worth.
Posted on Jul 24, 2009
Anonymous
  • 4 Answers
SOURCE: no power
Press TUNE+ & AUTO SURR/DIRECT keys continuously for 2 sec. and it will tell you the fault it encountered if the receiver is in otherwise working condition.
Posted on Aug 12, 2009
Anonymous
SOURCE: my thermoheat 210,00 btu kerosene heater works
SOUNDS LIKE YOU HAVE A BAD THERMOSTAT.
Posted on Dec 01, 2010
1helpful
Hello i have a kenwood vr309 that when i turn it on everything works but if i turn the volume up it turns off all sound until turned back down please help
Check the speaker protection circuit first. Make sure the proper sized speaker wire is used and in good condition. Your speakers may be failing electrically too.
Kenwood vr606 reciever shutting off subwoofer and centre speaker simultaneously after few minutes/seconds of powering on. WHat's the cause?
The receiver's out put sections are grouped in pairs. Front left and right in one output, rear left and right in second output, and center channel and sub output on the third. Sounds like a semiconductor or semiconductors have gone bad in the center & sub output.
1helpful
Why does my Definitive Pro Sub 1000 keep blowing fuses the second I put them in?
Sounds like the amp is shoot.
Never power on the amp without speaker connected.
My vr-507 shut down to protect my speakers but will not power up now.
Sounds like the output transistors in the amp are blown. Try powering on without speakers attached - if it still shuts off your amp is blown and needs to be repaired.
2answers
I turn stereo on and it shuts off after a few seconds
There is an output load on the receiver, turn off! remove speaker wires from back, power on and turn down the volume, if it holds! you have a short in the wires or one of the speakers. Now if if shuts down with everything dis-connected it means there is one or more audio outputs shorted.
1helpful
I have a vr 309 kenwood reciever with a bad subwoofer port because sub doesnt produce sound through it but does through another reciever, is there a fuse or capacitor just for this output i can check or...
Are you sure the VR309 is sending a signal out through the sub port? Attach one of your other speakers to it as a test (low volume). Then get back to us.
There are such things as user settings that affect this.
1helpful
I have a Kenwood car stereo KDC - MP4033 and the word "Protect" is flashing and i can't get it to work, no sound or stereo
check your speakers and speaker wires for shorts, and then disconnect power to the radio for a few seconds and reconnect it.
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
3helpful
2answers
Power Light off & speaker not working
I had the same problem. The screws around the perimeter of the back plate must be unscrewed and the plate must be pried off as it is glued to the box. When replacing my fuse, 2A 5x20 GMA, it blew the fuse again. Disconnecting the second circuit board prevented the next fuse from blowing, but now the question is what is wrong with the circuit board? I cannot see any damage or shorts.
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Thomas
Michael Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
