Question about Kitchen Ranges
When broiler is selected on FGEF306TMF it starts but then the Stove looses all power to the control panel.
Posted by Terry Strauser on
john h
    Top Expert:
  • Kitchen Ranges Master
  • 24,045 Answers
Circuit board failing [ overheating or shorting ]
Posted on Apr 07, 2020
5 Related Answers
Anonymous
SOURCE: GE Profile Spectra Broiler not lighting
I'm not an expert, and I'm reading you're post while looking for a solution for our oven, so this is in no way should be taken as a suggested solution, it isn't!!!....here it is anyway: I think it might be a bad ignitor, I have replaced a couple on our stove and both times we had exactly the same symptoms you're experiencing, I think also we're in line for a third ignitor for this "less then 10 year old Magic Chef". Good luck
Posted on Jun 17, 2007
aborcass
Ron Coons
  • 2651 Answers
SOURCE: MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Posted on Mar 06, 2008
Anonymous
  • 95 Answers
SOURCE: bottom /bake element will not come on
Check the connections to the element. If power is going to the element, and it is not working, the element needs to be replaced
Posted on Jul 21, 2008
Anonymous
  • 530 Answers
SOURCE: Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Posted on Jan 04, 2009
Anonymous
SOURCE: Whirlpool Gold GS395LEG oven won't start
oven does not light up, no heat
Posted on Mar 11, 2009
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
www.repairclinic.com/...Range-Stove-Oven/...-/Electrolux-Oven-broiler-...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/...Range-Stove-Oven/...---/Oven-broiler-not-worki...
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Kenmore elite stove model #7909912949B. Can get anything to work on oven. Light comes one. Nothing else in the enter panel. Top burners work.
Can you enter the oven temp and press start on the control panel? Do you hear it click on, but it just does not get hot? Try turning on the broiler and see if the broiler gets hot.
Where are fuses in Kenmore stove C970
Stoves generally do not have internal fuses they rely on the house circuit breaker to protect the circuit. Some stoves have what is called a thermal fuse. These can trip when the oven or broiler has overheated. Some are located on the back panel and some are located on the top panel under the top of the stove. Since this is a smooth top model there may be one on the back panel. More than likely there is a problem with the oven control circuit possibly in the electronic control. The relays can go bad on the control and the oven will not work.
I have a Kenmore Ultra Bake. Stove was on bake set to 375. Only the broiler element came on at full power. Tuning off oven did not turn off broiler element. Stove was to hot to move so I turned the braker...
Hi
F3-E2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
1helpful
2answers
My ge range has quit working. First the stove top (coils) failed to heat up (all at once); then about a week later the broiler coil failed to heat up shortly followed by the entire oven. The 'on' light...
The stove top is internally wired separately from the oven. Check that you don't have a faulty circuit breaker in your breaker panel. The oven is 240V which has two breakers ganged together. If only one side trips you can loose power to the heating elements but still have power to the control board (to light up ON).
1helpful
2answers
Oven and Broiler coils do not heat. Control works okay. The burners heat okay. Set oven to 325 degrees. Drops to 100 degrees. There is a click. and nothing happens beyond that. Try broiler. Set to HI. Does...
There is a relay in the back panel of the stove, this is probably the problem, there is also a temp thermostat in the back leading to the inside oven this cold be bad
1helpful
2answers
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
ADMIN Canada
ADMIN Canada
Are you a Kitchen Range Expert? Answer questions, earn points and help others
