Question about Westinghouse Televison & Video
I've got a Westinghouse 50-inch 4K TV and I think the back lights are out can you help I have a blue light and got power and I can see a picture in the back but the screen is is dead
Posted by Donna sue Andersen on
David Spradling
    Top Expert:
  • Westinghouse Master
  • 10,974 Answers
Check input or source also connections if ok possible bad video board or tuner
Posted on Feb 25, 2020
5 Related Answers
Anonymous
SOURCE: Hitachi HD 1080 has blue power light on but no picture
Press the reset button...it's on the bottom to the right (underneath the TV). Same thing happened to me.
Posted on Feb 24, 2008
Anonymous
  • 317 Answers
SOURCE: Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
Posted on Jun 03, 2008
cirocpatel
CIROC TECH SUPPORT
  • 524 Answers
SOURCE: got new tv Westinghouse LTV-32W1 32 Inch
in this case i have to know if your tuner is working fine or not. First of all i like you to connect any external player Exp. DVD or blue-ray player if that works with audio then it is inverter board. if audio doesn't work then its main board. Also you will find out that if dvd is working fine on your tv than your tv setting is wrong or the tunes is dead. either way if tuner is gone then you have to change the main board. Either way let me know what went wrong i can provide you more information about what part need and where can you get it from.
Please let me know if you have any further questions or concerns. Also rate me if you like this post.
Thanks.
Posted on May 11, 2010
Chi Chu
  • 8457 Answers
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 23, 2010
Jason Miller
  • 33 Answers
SOURCE: My Hitachi P50H401 50 inch Plama TV stopped
very common issue. if your hand you can repair it yourself.
for more info on this set please check out http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
if will tell you how to trouble shoot this tv. these tv's are known for two caps in the power supply to go bad and they need replaced then you have to test the sdr boards if they are bad you need replacement boards or you can send them off to be repaired. the link for the repair guy is on the page. this guy also sells the repair on ebay but if you contact him directly i beleave the price is lower. just tell him you were send over by home theater shack.
Posted on Feb 22, 2011
The TV powers on and even displays the brand logo when turning on. After that, there is no display on the TV but sound. I can see moving images in the back. How can I fix this?
Your backlights have failed, taking it to a repair shop for service will run between 150 and 200 dollars, you can replace the LED strips yourself but its not an easy job if you haven't did it before, its very easy to damage the panel when taking it apart and putting it back together then the money spent on the strips is wasted and the TV will need to be recycled...Good luck!
Aug 19, 2018 | Westinghouse Televison & Video
Westinghouse ew32s5kw tv red light shows power is going to unit pressing power turns indicator light from red to blue for a brief moment then back to red.
I had the same problem on my Westinghouse 32 inch TV. The internal main power supply went bad and had to be replaced. I had a TV repair shop do it. It was about 8 years ago. Haven't had a problem since. I think it cost about $70 for parts and labor. Nowadays TVs are pretty much a throw away item if they go bad. TV repair shops are getting hard to find plus the cost of TVs has come down so much sometimes you can get a new set for what the repair would cost!
Oct 25, 2017 | Westinghouse Televison & Video
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
Blue screen, no picture, audio works fine. TV
I have the same issue. I am thinking I need to replace the T-con board. Did you get your fixed and what did you need or do?
Oct 01, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
50 inch phillips hdtv model:50pl9126d/37, no picture...
Unplug for one hour then plug back in---worked for me--computer resets
Mar 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Aug 31, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Mar 06, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Hitachi 50" plasma no picture
how do i fix p50h401 blue light no picture and sound
Feb 07, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Televison & Video Logo
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
