Typical operating voltage range is 4.75 to 5.25 VDC and 0 to 70C operating temp.
Testimonial: "Thank you. I figured that 4v was way out of range. I might try just a new power supply board, but if it's not the whole reason just stop there. At that point a new set of UI boards probably would not be worth it. Thanks for the information."
SOURCE: whirlpool duet dryer
look to the furthest right set of buttons, the lowest button on the furthest right column is marked as control lock, press it for 3-5 secs and it will unlock your controls
SOURCE: Whirlpool duet electric dryer, not getting any power
Mine shows a faint light behind the control locked indicator and the timer is dimly lit on the two middle horizontal bars (middle of the eights). They go off by pushing various button combos. If I unplug it for a week I can get the control to work for a few minutes.
I replaced the control board, it worked for 5 minutes, then back to nothing. I want to replace the interface but would rather not waste any more money.
I dont want to check every wire for continuity. If someone has fixed this problem, please let me know.
SOURCE: Whirlpool duet washer dryer, Dryer is stuck on control lock
look to the far right buttons labled control lock, hold it in for 3-5 secs, to unlock
SOURCE: Whirlpool Duet washer stuck in "control locked"
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
SOURCE: My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
