Question about IBM Computers & Internet
Unlikely that it will allow you to do so, without editing the files it uses, which I doubt you will learn how to do for such an old program. Instead use the Export menu in Lotus Organizer, and then import that file into another program, such as Microsoft Outlook or the free program, Essential PIM.
https://www.essentialpim.com/
http://store.stamps.com/web/site/robohelp/ipostage/creating_a_csv_file_in_lotus_organizer.htm
Posted on Feb 22, 2020
RTM , on the APP, be first.. good luck this old, finding it.
google all day?
SOURCE: Changing Font Size
To change the font size you need to install a different printwheel. There are places on the internet where you can order one along with an owners manual just do a search for the make and model.
Posted on Apr 21, 2009
SOURCE: IBM 6400 Dot Matrix Printer - Need Drivers for Windows XP
Try running couple of these test, to see if it might be another issue.
It should be printing these test at 1500 Line Per Minute... ?
1500LPM is at 10CPI if you have (Font size: 6, 8, 12, 14) it will make a difference.
Change your driver to Generic/Text, rerun your report... any difference?
Posted on Sep 10, 2009
SOURCE: how do i change the font size on a Wheelwriter
The font size is set by the printwheel, the printing on the P/W case will tell you the pitch 10, 12, 15 or PS. Change the wheel change the pitch.
DickyO
Posted on Dec 07, 2009
SOURCE: How do you change the font size on the ibm
The WW3 will type whatever printwheel is in the machine. If you want something different you will have to buy another printwheel. It says on the printwheel whether it is a 10 pitch or a 12 pitch.
Posted on Jul 17, 2010
SOURCE: Toshiba Laptop spontaneous font size change
Disable the dreadful "pinch-zoom" of the Snyaptics touch pad.
How it is supposed to be used is at
http://www.synaptics.com/solutions/technology/gestures/touchpad . However, I tried these "gestures" and none of it worked on my touchpad.
On Windows7, one can disable this poor excuse for a feature by going to Control Panel->Hardware and sound->Devices and printers->Mouse->Device Settings->Settings [button half-way down, on the right]->pinch zoom. Then uncheck "enable pinch zoom".
Posted on Oct 16, 2010
Press Ok, Accept or
replay
I have a solution for
this
Bruce
