I have a DVD VCR combo and when I power it on it will shut off within a few seconds. Theres a green light flashing and I think that the initials next to it is CST can you please help me with this matter
Posted by Roger Bean on
    Top Expert:
  • Televison & ... Master
  • 76,625 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty.
Posted on Mar 08, 2020
5 Related Answers
Anonymous
  • 48 Answers
SOURCE: DVD VCR COMB
That's not uncommon. One side fails, the other side can't play. You need to get the tape out and make sure that if you break the tape that there are no pieces stuck int he mechanism. You may need to crack it open to get to the inside to remove any broken tape. Be VERY careful around the heads. Blow it out and use a good head cleaner to clean the heads. Then see if there's a reset procedure or simply unplug it for awhile.
JD
Digital-Camera HQ
Posted on Dec 01, 2007
Anonymous
  • 20 Answers
SOURCE: help
I fix these all the time, change end sensors and Infra red Diode. Do not attempt unless you Know how ! Diode is under loading deck. Sorry if you are a novice bring to shop! Sorry It is easy only if you know what your doing remember change center IR sensor ( center diode on PC board. Also end sensors (2) one on left one on right side. Do not attemrt if you dont understand ! www.Irionstvshop.com Hope this helps.
Posted on Mar 04, 2008
Anonymous
SOURCE: CST.IN Light
Put a tape in and eject it. It will then work. Just had this problem. CST IN means the VCR thinks it has a tape in. Trust me... Very fixable.
Posted on Nov 15, 2008
Anonymous
SOURCE: VCR runs a few seconds when I insert a tape then shuts off power.
You have to change the two VCR rubber bands
Jc
[email protected]
Posted on Mar 11, 2009
John Cunningham
  • 6771 Answers
SOURCE: I put a vhs tape in an the vcr turns off by it
Unplug the power supply for thirty seconds and plug back in, this will reset the processor and might eject the tape. If this fails the next step is remove the top of the combo unit this will give access to the vcr tape, if the tape is spewed in the machine and wrapped around the video head and other mechanical parts use scissors to cut the tape and carefully removing the particles, press power to eject the tape for normal operation. However! if the vcr tape is okay, there may be a loading problem, broken drive belt, bad idler assembly to name a few, this is where a technician will be needed but may not justify cost.
Posted on Jan 23, 2011
Small green light flasing on the front of the tv..think it says programable timer..how to shut it off ?
It is stupid as it serves no purpose at all-----I have removed a few----and several people I know have used a carefully cut piece of black tape to cover it up.
3helpful
I put a vhs tape in an the vcr turns off by it self a green light keeps flashing by where it says cst in. I have a Hitachi DVD/VCR COMBO DV-PF2U. I also can not get the tape out
5helpful
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
SRCD227 tv/vcr/dvd won't stay on
QUE CLAVE O TECLAS DEBO OPRIMIR PARA ENTRAR AL SETUD
My combo will shut off a few seconds after you turn it on
Get a very small hemostat, or heat sink clamp and clip it onto the wires coming out of the diode, batween the diode and the board. Use a small soldering pencil so you don't generate too much heat and use solder remover braid or a ****** to remove the solder. When you replace it, use the clamp again to protect the new one and make sure the polarity is the same or it won't work at all.
3answers
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Tv shuts off
sir i think theres something wrong with its power supply,,thnkss and hope to help you!!
Sylvania SRD4900 DVD/VCR combo problem
There's a problem with the tape drive, so it's shutting down to prevent damage to the tape. Someone familiar with VCR mechanisms would probably have to see it in action to identify what's wrong. Most of them act in a similar fashion, so if you have a working VCR, you can take the cover off and watch it load a tape, run it, rewind and eject, then compare with the non-working unit. The parts won't be interchangeable, but the tape loading will look much the same. You can comment on what happens and I can try to explain what I think is going on. Better yet, if you could post a video of the internal mechanism while it tries to load a tape, that would be very helpful.
3answers
Locked DVD/VCR Combo
Hold the power button down for 5 seconds fixed it for me.
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
