Why dose my TV turn off by it self - Televison & Video
Posted by flora on
Tom Chichester
    Top Expert:
  • Televison & ... Master
  • 61,813 Answers
The power supply could be failing. You also may have a sleep timer set
Posted on Nov 08, 2020
Error code 15 on a jura giga professional x7 coffee machine
Dear sir ,
Please help me, Now my coffee machine Jura GiGa X7 Professional , When i start turn on machine maybe 15 second it turn off by it self.
Hi guys!my garmin turns on but keeps saying it's looking for satellites, what do i need to do to make it work. I'm outside with a clear view of the sky
Ok well every satellite dose that ones you turn it on after a while, I have a Garmin GPS my self and it always dose that like for a minute and until that I just drive, after like a minute it shows that satelites is found and will direct you to your location
Sony FD Trinitron WEGA Tv - LAMP blinking 11 times
Sony tv has self protection program. The red Led blinking light indicate the probable cause location. For this model it is either 2,4 or 5 flashes every 3 second. Please check the blinking again
My tv dose not turn on , its show power light red and when I plug in its sound like timer and , then screen turn grey, I can not change any mode or volume , and can not turn it off , I have to plug it out,
hello sir,
please sir solve my this problem.
my tv dose not turn on , its show power light red and when I plug in its sound like timer and , then screen turn grey, I can not change any mode or volume , and can not turn it off , I have to plug it out,
Mits big screen vs-60707screen comes on red then turns off 10sec
either a bad red crt or bad transistor on the red crt pcb!
I have just been given a Samsung sp42w4hb back projector TV that has a problem,after about 4 power cuts in the area the TV went off and only the standby light comes on,it stays on for about 10/15 seconds...
check to see if you have a loose conection at the relay or at the power source a lot of times the relay goes bad and you can solder a neew one in get a service manual to locate relay and parts
MICROWAVE NOT WORKING PROPERLY
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Otherwise, it sounds like a bad door switch or door switch mount.
Screen dose not open its self
yes i have the head unit on its wn fully working do you want to buy?
cheers my number is 01706523488 im called saqib
ill give it for 100 delivered to your house and will like postal order payment
cheers mate
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
