SOURCE: Timer/Standby light blinks but no picture or sound when power button is pressed.
I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
SOURCE: 37FD9954/17
hi, i have read somewhere that you need to replace both 100u / 25 caps aswell.
the info came from a user on here called PaleFace but i cannot find the original post now and i have the same problem with my tv.
SOURCE: t.v on standby, red light flashing 3 times, wont switch on
Shutdown with a 3x blink pattern occurs if the 12v from the power supply (GF1 or GF2 depending on model) is lost at CN6153/pin 6 to the AU Board Q1224 to Sub Micro IC1205. The suspects, in order of likelihood, are (1) Power supply and (2) the AU board.
SOURCE: I have a panasonic flat panel tv 1080i. 46
the s1 models have been having several problems. it really depends on how many times the red led is blinking. panasonic uses a certain number of blinks to tell you what board has failed. the s1 models have just recently come out. therefore your tv should still be under manufacturer warranty. call panasonic and see if there is a servicer in your area. our company is in dallas texas. Aces Tv Service.
